Make sure the OBD2 is being connected in the correct orientation.
If so, you might have water damage or physical damage to the board. Best to post pictures of both so we can help.
Thank you Payam.
OBD2 orientation and the connector between JB4 and the OBD cable are in the correct orientation. JB4 function perfectly fine until I switch off the car after that I get the code.
I sent an email to Terry and he advised me to disconnect the BCM connectors and check. I will try that on the weekend.
Thanx again
