shawn_tx shawn_tx is offline
Car: BMW 550i RWD
Default MAP 6 Questions - 02-08-2020, 12:41 PM
1.) Are all boost values in map 6 absolute or additive for the N63 NON TU?
2.) Do any if the values under user adjustment affect other maps such as map 1 or map 2 such as PID Gain, FOL Default Wastegate Pos, etc? Or do those values only affect Map 6?
3.) Is it possible to get or see/view all the settings for MAP 1, MAP 2 (compared to MAP 6 default values?)
2011 550i
SINasTER's Avatar
SINasTER SINasTER is offline
Car: BMW 335xi E90
Default 04-05-2020, 11:56 AM
It seems there is a let go from the comunity since a couple months now, also posted some questions and even though it’s getting read, no answers yet... will try to help as best I can
#1- from my last conversation with Terry, additive boost on map 6
#2- appart from boost by rpm (for custom tune, I think most other values affects all other map (my car runs better since I played a bit with the wastegate position and duty bias)
#3- only the dev team could help you on this one...
BMW 550 M-Sport xDrive 2011
HPE DME Stage 2 tune
JB4 backend flash
Custom valved exhaust with 3" quad tips
Custom 3" D.P.s
ESR RF2 19" wheels
Front: Firestone Firehawk Indy 500 235/40R19
Front: Firestone Firehawk Indy 500 285/35R19
ITPhil ITPhil is offline
Car: BMW X6 50i
Default 04-11-2020, 04:08 PM
Thank You SINasTER. I would just like to learn before I make a mistake.
Car: M550i
Default 06-20-2021, 08:47 AM
#3 is a good feature request
Say you are running map 2 and its all good bar one aspect and you want to take a bit of boost out of the lower rpm for example, why cant you load map 2 into custom editor and start with the default values then save it as your map 6 once done?
Default 06-21-2021, 10:24 AM
#3 is show in every log you take as the "target".
Car: M550i
Default 06-21-2021, 02:42 PM
Boost target is additive in map 6 yes? Is there a manual to read on all the others settings?
Default 06-22-2021, 01:41 PM
For the F-series that is correct. Boost target (pink line) will show the additive value throughout the RPM range.
