Wsmith1118 Wsmith1118 is offline
Car: 2012 135i 6MT M Sport
Default SES Light - 10-12-2019, 07:09 AM
New to the forum, picked up a 135i back in March. Having some problems now. Getting a 2775 code and also what seems like a throttle cut when going WOT according to logs. Was hoping someone could take a look at the log and tell me what they see.
Work and mods Iíve done since Iíve had the car:
Alternator
Intake manifold gasket
Chargepipe o-ring
Boost solenoid
NGK 97506 plugs gapped at .020Ē
BMS cowl filters
BMS Intake
JB4
And possibly more Iím not remembering at the moment.
Default 10-12-2019, 11:06 AM
MAF sensor leaking perhaps around intake tube coupler?
Default 10-12-2019, 02:14 PM
I’ll check that. I boost leak tested before, from the hot side of the intercooler to the intake manifold. Didn’t see any leaks. Forgot to mention I also have an Evolution Racewerks Chargepipe. So to you this looks like a boost leak? Also it seems as though when I’m WOT the boost oscillates back and forth around 10-12 psi. Like I can hear it going up and down.
Default 10-15-2019, 08:22 AM
How much pressure did you use for the boost leak test?
I’d physically inspect first
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 10-29-2019, 03:01 PM
I visually inspected everything first, then was able to get maybe 10 psi in before it started gushing out from where I had the tester connected. I was doing it from the hot side of the intercooler. So possibly a leak from the turbo to intercooler I guess. Boost leak testing from the intake pipe only resulted in it coming out from the inlet to turbo seal since that normally does not see pressure. Not sure of a better way to go about testing it.
Default 10-29-2019, 03:02 PM
Also note, if I do not have the JB4 connected at all (stock time) the car throws no codes. But does seem possibly sluggish still.
Default 10-29-2019, 03:07 PM
Another note, installing the jb4 after I removed it to get it to set readiness for inspection, I did attempt to ground the jb4 on to the positive cable thinking it was a ground (yeah I know). Which in turn blew the ground for my tmap and I have now since ground the tmap to the strut tower.
Default 10-30-2019, 12:08 PM
since jb4 re-installed- log?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 11-19-2019, 04:26 PM
Sorry I have not gotten back to you. This is a log from today after replacing the ignition coils and resetting adaptations. The only codes I normally see besides tuner codes are 2775 and 3166.
Default 11-22-2019, 12:19 PM
Boost looks better here.
Fuel?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 11-25-2019, 09:15 PM
As in fuel grade or fueling problems? I normally run 93. Fuel pressures look good to me according to the log.
Default 11-26-2019, 08:58 AM
Grade
That last log looked about right for 93
e92 AT 335xi 2.0
Doc Race Kit 6062
