Originally Posted by BeatupVR4
First off I'm jealous of the brake rotors you picked out. I was a cheapy and got the Pagid OEM aluminum hat ones but that was it.
I ended up here because I wanted to get a decent set of slotted rotors, but to get something that wasn't a bottom basic disk was quite expensive and helped to justify getting these 2 piece rotors. Sure they are drilled and that is... tacky, but they should still be a huge upgrade over OEM and do look better than plain discs, so here we are
I probably would have reused my "fork" but the LUK 550i clutch kit came with a new one so I just used that. I don't see a throw out bearing on there and I would definitely recommend that. Also make sure you install it on the right step height. There is a low and a high one and I think you need the high one but double check that.
I've since added the fork and bearing to the flywheel optional addons. thank you!
IMHO the rear main seal tool isn't needed. I just put two deck screws in mine and used pliers to pull it out. It comes out fairly easy. Even that and the OEM tool use screws.
I found one for 50 bucks and 40 bucks delivery on aliexpress.com, though after watching some videos, no way. i have a strong hook i can use to remove the seal. looks very easy.
Putting it in with the supplied plastic spreader is also super easy. NEWTIS is closed now but there is an installation depth you want to look out for.
I'll take note of the factory install depth. Not sure what NEWTIS is.
For the slot where the lower engine cases meet the rear main instead of the loctite kit from BMW I used grey RTV and pushed it in and spread it around. Still super dry under there.
Interesting. I searched this after reading your comment and others have the same comment as you have. I'll try to find a video of exactly what you're talking about.
Are you using the Silicone sealant or the gasket maker?
This stuff?
https://www.canadiantire.ca/en/pdp/p...-0383724p.html
Thanks for the help!
