(#201)
Default 06-16-2020, 09:18 AM
Originally Posted by Scottyboi10
I installed the jb4 last week along with the mishimoto cold air intake and charge pipe and it has run smoothly until today when I tried adding a little bit of e85 to some 91 octane and running map 3. Now all maps missfire including map 0. Did I add too much e85 or something. I will attach some logs
Update to the BETA firmware and grab a log on map0 and map1, you can set the app to combine logs it's easier for us to view that way.
Scottyboi10 Scottyboi10 is offline
Car: Jeep Wrangler
Default 06-16-2020, 12:21 PM
Here you go sir, the Jeep has started misfiring less on map 0 than before. Also how far off are we from running meth injection on a Jeep 2.0t?
Default 06-16-2020, 04:25 PM
If you were getting misfires should have fault codes to go with them. If it's simple stuttering maybe just need to tighten up the plug gap?
We have Jeep customers running WMI now, the JB4 firmware fully supports it.
drburns drburns is offline
Car: 2020 Jeep Wrangler Rubicon
Default 06-16-2020, 04:32 PM
Would you recommend just going ahead and tightening the gap, or just run colder plugs to see if that fixes the problem? I don’t know if that’ll help since it seems to happen almost exclusively on the 1-2, 2-3 shift. On the fly it feels fine.
Default 06-16-2020, 05:23 PM
It depends what the issue is. If the issue is boost dropping as some of you have shown in logs then no, plugs won't fix that. If issue is stuttering and spark blow out with boost normal. Then yes it might.
jw1971 jw1971 is offline
oceanblue2019
Car: Jeep JL
Default WMI? - 06-17-2020, 09:15 AM
Hi Terry - by WMI do you mean customers on the Jeep running water/methanol injection? If so can you give more details on the setup.
Default 06-17-2020, 10:57 AM
The JB4 supports it but you'd have to drill/tap the chargepipe for the nozzle. Not something we have any info on other than the tuning side. Our WMI kits are all fully compatible of course.
Car: Jeep Wrangler
Default 06-17-2020, 09:10 PM
Just thought I’d mention that I refilled my Jeep with just 91 today and everything works fine again. Maybe it’s the e85 I was using or something weird like that. Also I am very interested in running just e85 and wmi. How would I go about running wmi and getting it set up with my jb4 and everything. Thank you
Vinniechin Vinniechin is offline
Car: Jeep rubicon
Default 06-18-2020, 07:39 PM
What gauges are you guys using it monitoring with the app? Thanks.
Default 06-19-2020, 05:11 PM
Once everything is ironed out, I’ll use boost, afr, trims, iat, Avg ign, map. When I was setting up the pedal tuner I had pedal and throttle on the display. While we’re still getting everything sorted with the maps, I’m also looking at target boost and ecu boost. Mph, rpm, and water temp are on the stock gauges In front of you so I don’t see a point to putting them on the jb4 display.
Car: Jeep rubicon
Default 06-19-2020, 05:39 PM
Awesome. Thanks. Will try your settings
Default 06-21-2020, 07:14 AM
I installed a Mishimoto cai on the Jeep this weekend and did some more testing. Map 1 seems to run pretty good, no hesitations. Map 2 continues to be an issue, but only with full throttle standing starts. If I roll into the throttle from a stop, it seems fine.
Gabiyaniv Gabiyaniv is offline
Car: 2019 JLUR 2.0T
Default 06-27-2020, 02:30 PM
Hi
Just got the BMS WMI controller, im planing to use my Snow Performance pump, solenoid and nozzle.
My setup is Mishimoto IC pipe and a DV+
I'm running 98RON exclusively
What is the best configuration to start with?
Which map the WMI is enabled?
Anyone have expriance with WMI on 2.0 JEEP?
Default 06-28-2020, 09:52 AM
It's still new but as for the wiring:
FSB orange to 3, FSB blue to 6, set meth scaling = 60, meth additive = 40, meth trigger = 1 (user adjustment page), which has meth flow on all maps to start. And then log map1 or map2 so we can confirm meth is flowing properly before getting in to the progressive mapping and safety.
Car: 2019 JLUR 2.0T
Default 06-28-2020, 11:36 AM
I tried to prime the system and nothing happened, how can i tell the FSB is working? Do i need to enable it somehow?
Default 06-28-2020, 01:29 PM
Need latest firmware and to be on the WMI map 7 to test purge.
Car: 2019 JLUR 2.0T
Default 06-28-2020, 01:36 PM
That worked, i flash the JEEP3 firmware and it did prime on map 7
Will post some logs as soon as i figure connectivity issue
mhrdch mhrdch is offline
Car: 2020 Crystal Granite JLUR Recon Edition
Default 06-29-2020, 12:51 PM
I got the JB4 about a week ago. I have the mobile app and bluetooth connection, and everything was running smoothly. Two days ago, I got in an accident which resulted in me damaging my right front fender, popping my front right tire, and possibly messing up the suspension. In addition, I have a CEL. Might this be related to JB4? Should I remove? Is there any quick fix? I'm not taking it to the dealer (3rd party repair shop), but I don't want to mess up my warranty (it's a 2020).
Car: Jeep Wrangler
Default 06-29-2020, 02:59 PM
Does the jb4 work with the tazer mini?
Car: Jeep rubicon
Default 06-29-2020, 03:07 PM
Yes it does. I have both now.
Default 06-29-2020, 04:50 PM
You just need to read the code.
Default 06-29-2020, 06:15 PM
Hey. I'm a bit of a novice at all this stuff. The codes are 2174 and 0703. I've changed to Map 1 and restarted, and read and deleted codes but CEL always appears on startup. I haven't been able to drive the car because of the accident so it hasn't been on much. Any suggestions? Thanks so much for the response.
Default 06-29-2020, 08:12 PM
Something with the throttle actuator, I'm not sure if it might be JB4 related. I'd just pop off the JB4 until you know the car itself is 100%.
Car: Jeep Wrangler
Default 06-30-2020, 01:54 PM
Are you using an obd2 splitter?
yellowssm yellowssm is offline
Car: 16 BMW M4
Default 07-01-2020, 07:52 AM
Just noticed everytime I jump back in my Jeep it defaults back to map 0 instead of the map 1 from the last time I was in it? It didn’t do that on the previous 3 jb4 vehicles?
