Ifreezebmx562 Ifreezebmx562 is offline
Car: N54 335i
Smile Someone please help me, N54 misfire - 05-25-2020, 02:55 AM
Whatís up everyone, Iím hoping someone can help me with these logs I have attached here to figure out whatís up with my car. When I hit boost it starts to misfire... I put 2 gallons of E85 in today and also just upgraded my FMIC to a 7.5 and my car started to act weird. I tried to figure it out with a friend of mine also but we couldnít really see whatís wrong because we donít know whatís acceptable and whatís not. Thank you for the help guys really appreciate it!
Also I only misfire under high boost.
Also on JB4 itís cutting boost Bc of AFRís to lean.
Geo335's Avatar
Geo335 Geo335 is offline
Car: 2007 335i
Default 05-26-2020, 03:13 AM
Logs should be WOT 2k rpm to redline, 3rd gear, traction completely off.
2007 e90 335 - BMS DCI - JB4 - feline less - AFE scoops -VRSF CP - HKS BOV - VTT PCV - BMS Cowl Filters - Muffler Delete - PUMP BEF - e30
Car: N54 335i
Default 05-26-2020, 03:23 AM
This is the closest thing I got.
Car: 2008 E93
Default 05-26-2020, 02:58 PM
What cyl misfires ? Bank 1 ?
What plugs are you running ?
What coils ?
How old ?
Car: N54 335i
Default 05-26-2020, 05:44 PM
What coils ?
How old ?
I currently swapped back to my Bosh plugs. From FCP Euro
The coils are Delphi
And they are both under a year old.
The coils have been used constantly but the plugs were used for about 6 months.
Iím getting a AFR drop only under boost. Itís dropping down to 10.7 on a log I saw today which is means JB4 is just cutting everything. But it doesnít make sense why it only cuts cylinder 3.
I also have brand new index 12ís that Iíve been running a week before the problem.
Car: 2008 E93
Default 05-26-2020, 05:58 PM
Jb4 shouldnt cut anything at those AFRs.
Where did you get the index 12s from ?
Im going to guess (since no good logs), that would be your issue.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 05-26-2020, 06:33 PM
Just to confirm that you coded the new injectors?
Car: N54 335i
Default 05-26-2020, 08:09 PM
Yes! I coded with protool.
Car: 2008 E93
Default 05-26-2020, 08:14 PM
Purchased from ?? (Injectors)
Car: N54 335i
Default 05-26-2020, 08:16 PM
Fcp euro
Car: 2008 E93
Default 05-26-2020, 08:19 PM
Fcp euro
Pull the one that misfires and see if it smells of gas
Or swap it with another bank and see if it follows.
Car: N54 335i
Default 05-26-2020, 08:45 PM
Did you have the same problem?
Car: 2008 E93
Default 05-26-2020, 08:48 PM
No, but running rich and misfiring leads me to believe injector
albertc albertc is offline
Car: 2007 335i
Default 05-26-2020, 11:16 PM
Cams position sensor could be bad as well
Car: N54 335i
Default 05-29-2020, 02:41 AM
swapped injector from cylinder 3 to 2
same problem.
Car: N54 335i
thats one thing i have not changed... but would that cause a single cylinder misfire constantly?
Car: N54 335i
Default 05-29-2020, 02:43 AM
Ive attached a new log from today.
today i put a MHD BEF on my car in hopes it could be something with JB4 not having a BEF and nothing.
same thing happened with AFR Lean cuts.
