Car: 2009 e90 335i
Lambo "e gear" through tuning? -
04-02-2020, 06:33 PM
Pardon me if this is a dumb idea. Since yesterday MHD released a stand still burble update for us, I am interested in revving out in neutral while rolling the way supercars do.
Is it possible to do this through tuning?
Maybe even deleting D MODE and tricking the TCU to think D MODE is neutral?
mhd.xhp stage 3.dci.inlets.deepees.cp.x pipe.pe mod.stage1 lpfp.e40.
Car: 2008 E93
04-03-2020, 11:25 PM
Ummmmm....
Put the car in neutral maybe ???
Car: 335i E92 2009
04-04-2020, 07:26 PM
Seems the new MHD burble feature released few days ago works only on P and not in N and the normal burble on the specific rpm you set on the D,
Maybe send email to MHD and ask him if he can let you use it on N instead of D or if he can add it as check box to his options
Car: 2009 e90 335i
04-04-2020, 07:48 PM
Good idea. I contacted xhp and a custom TCU tuner and they both said it would be very difficult. Xhp said they are looking into it but it would take some time to develop.
And I would swear that I am getting pretty hard burbles in neutral. I'll have to test it out tomorrow
Car: 2008 E93
04-05-2020, 11:00 AM
As I said
Put it in neutral
Even IFFFFF, you trick the tcu to put in neutral while actually in D mode.....what the hell do you think you are doing ?????????
Putting it in neutral ....or am I mistaken ?
Drive down the street around 30mph or whatever, put in neutral, do your revs, put back in drive. The trans will know what gear to go back in to. Its not like it will downshift to 1st or anythng like that.
Kinda a dumb idea as you said in 1st post (IMO), BUT, I already told you in my first response.......you want neutral, put it in neutral for fux sake.
Car: 2009 e90 335i
04-05-2020, 11:18 AM
As I said
Put it in neutral
It always makes me laugh when people talk aggressively on the internet. So easy to say nothing at all. I wish you well
Car: M5
04-05-2020, 11:19 AM
Like THE Beast said, and let the rpm go down to idle before putting it to D.
Tue
Car: 2008 E93
04-05-2020, 10:02 PM
Lol, try n help this guy and he thinks its aggressive. My first post clearly said put it in neutral, and you seem to understand that as well.
Hats off to you.
Car: 2009 e90 335i
04-05-2020, 11:51 PM
Hats off to you.
No worries. I misunderstood you. Thanks for the suggestion.
Car: 2008 E93
04-06-2020, 12:04 AM
All good man, it happens.
04-06-2020, 05:50 AM
Get it up to 7k in D and slam it into P. Should get the noise you are looking for. Skip reving in N.
Got Boost?
Car: 08 E60 535i
04-12-2020, 09:15 AM
As I said
Put it in neutral
Brandon
Hayden, Idaho.
* 08' 535I. * JB4 W/ Bluetooth Connect & custom tune. * Billy Boat 535I 3.5" *****-back exhaust W/ resonator delete. * BMS DCI. * NGK 2 step colder plugs @ .020" (And I mean .020" on money!). * New Eldor coils. * BMS BOV adapter and BMS Vac side OCC. * BMS Chargepipe. * TIAL BOV W/ Hard 1/4" Vacuum line W/stock spring. * XHP Stage 2 * C-@-T TUBES.
[/SIGPIC]
Car: 355i
04-15-2020, 04:57 AM
Mine will pop and burble in N...in addition to P with the newest MHD tune.
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Down-p1pes, Bilstein B12 Prokit Suspension,G-Plus FMIC, MHD Stage 2+ tune, xHP stage 3 transmission flash.
04-15-2020, 07:52 AM
This and a previous post suggest that MHD had configured N the same as P.
You can e-mail to confirm, but if you have the expected results, seems you're there.
I and my customers (non-automotive) tend to chase after the most complicated way of doing things too.
That's why I always focus on 'what their end goal is', rather than their, 'can i do this to get this?'.
With the end-goal understood, Neutral is the solution.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Thread Tools |
Display Modes |
