Megamind's Avatar
Megamind Megamind is offline
Default need help - 02-12-2020, 10:37 AM
hi guys my jb4 keeps kicking me from map 5 to map 4 please help I have attached the logs this is my first turbo car and trying to learn
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 02-12-2020, 10:58 AM
Post in the support and log section
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
BMS DCI - BMS OCC - NRW CARBON COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5” RACE FMIC
VRSF DP’s - VRSF INLETS - VRSF OUTLETS
BMS PEDAL TUNER - RB PCV VALVE - 3.5 BAR TMAP
NGK 97506 @.022 - PFS STAGE 2 LPFP - H&R SPRINGS
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 25 ROW OIL COOLER
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
MISHIMOTO 15 ROW TRANSMISSION COOLER
19” 666m WHEELS - HANKOOK VENTUS V12 EVO 2’s
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 02-12-2020, 11:25 AM
Your boost safety set to 18 psi and you are hitting 18 psi and kicking you to map 4, you are over boosting which you need to see why.
You may for now raise your boost safety to 19 psi or 20
Megamind's Avatar
Default please help - 02-12-2020, 02:55 PM
car is a 2009 335i automatic 43k on it
vsrf charge pipe tial bov
bms dci
jb4 g5
Default 02-12-2020, 04:18 PM
Hey,
Welcome!
Your overboosting- raise your boost safety up to 20, and save.
While you are in that menu, also, enable your 6cyl logging too.
You can also, manually lower your FF setting to 70-80.
Megamind's Avatar
Default 02-12-2020, 05:57 PM
Hey,
Welcome!
Dave how do I get to those setting ?
Default 02-12-2020, 07:11 PM
Raise boost safety to 20 psi.
Lower FF to 80 and get another log on map 5.
What fuel are you on?
Enable 6 cylinder timing.
Default 02-12-2020, 07:22 PM
No need to create 2 threads, combined them for you
& glad to see me / Payam are on the same page LOL.
You access those via your user adjustments - you need either a laptop or a tablet
Megamind's Avatar
Default 02-13-2020, 09:31 PM
thanks for the help I changed the settings and pulled some new logs . I was running an E30 mix but when I started having problems I changed to 91
Default 02-14-2020, 08:55 AM
Last log looks okay- a few timing corrections, but that’s likely due to 91 octane
Still need to raise your boost safety
