Default BMS Fuel Pump Controller - 11-02-2019, 09:19 AM
New BMS product in testing phases now, a stand alone universal style fuel pump controller that can run your 2nd (and maybe 3rd) fuel pump.
Installation is really easy. Just give it 12v, ground, it has an output wire to power up your fuel pump, and finally a voltage input for the trigger which you can attach to your map sensor. Inside the box there are two dials, turn on (30% min dutycycle), and max flow (100% dutycycle), so you can set when the pump starts and when it goes max flow, relative to the input voltage or engine boost.
We're also evaluating having the trigger wire read dutycycle so rather than running a wire to the front for boost you can have it trigger off the factory EKP dutycycle for a really clean/simple install. In this trim you could set the 2nd pump to turn on only when the first pump goes 100%.
Finally we should also be able to configure this in a "load balance" mode for those running a single pump but worried about burning out their factory EKP. In that implementation this will sit in parallel with the EKP splitting load to the pump so the EKP sees roughly the same current as a factory fuel pump. More testing required on this specific implementation but it seems promising.
Intro pricing will be around $200.
Domino_86's Avatar
Domino_86 Domino_86 is offline
Car: 335i sedan
Default 11-02-2019, 10:22 AM
Great ideas always coming from the geniuses at BMS. I appreciate all that you guys do. Following...
Zeezul's Avatar
Zeezul Zeezul is offline
Car: e92 n54 pre lci
Default 11-02-2019, 01:02 PM
Great news! I'll definitely want this to supplement my stage 2 fuel pump.
FBO MT N54 w/stock turbos-tuned by Trebila
XXXDrive XXXDrive is offline
Car: 2010 E92 335
Default 11-03-2019, 12:02 AM
WOW BMS innovation keep pushing the envelope.I'm in for this
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 11-03-2019, 04:15 AM
Very interesting! In single pump load splitting mode does the factory ekp and ECU control the lpfp completely? So in effect the BMW unit is just splitting power and nothing else?
Also does this hook up straight to the battery, and if so does it go to sleep to prevent battery drain? I mean you can have it mirror off of the factory EKP, if that goes off the bms unit goes into low power mode.
Mods: Stock for now
JuniorB JuniorB is offline
Car: 2007 e60 5 series
Default 11-03-2019, 03:41 PM
If you were to use this to power a second pump, where’s the ground for the pump?
Lowon's Avatar
Car: Bmw M2
Default 11-03-2019, 11:08 PM
Also where would this mount on an F series? Specifically the 2 series/m2
Mods: Stock for now
N54_ABQ's Avatar
N54_ABQ N54_ABQ is offline
Car: 2007 BMW E92 335i
Default 11-04-2019, 08:53 AM
Awesome! I will be following development closely.
I always wondered the possibility of a "large current transistor" using the EKP signal to run a seconday pump. Glad to see BMS continuing to develop solutions!
2007 335i E92 6MT FBO, Stock Turbos
Default 11-04-2019, 11:03 AM
Black wire goes to ground
Red wire goes to 12v (fuse inline amp depending on pump IIRC 25amp max)
Orange wire goes to Tmap 0-5v (trigger)
Yellow wire goes to Pump Positive
Pump Ground goes to battery or grounded to chassis.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 11-04-2019, 11:59 AM
Would love to see a comparison log to the hobbs switch method. If you can make it so the pump doesn't fluctuate all over the place when the second pump comes on I'd say this is a huge winner
09 335 - 6266
07 335i - 6870, E85 - SOLD
Default 11-05-2019, 03:12 PM
I was thinking the same thing on the ground after I posted, and realized jb4 only has a power for a aux power.
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 11-06-2019, 01:27 AM
"2nd pump turn on only when the first pump goes dutycycle 100%"
in that scenario the first pump trim will drop then the 2nd pump will switch off.....!
How the 2nd pump will act, on off on off....?
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
Default 11-12-2019, 02:44 PM
OK we beat the hell out of one of our test models the last week including 1/2 mile racing at NFZ and it's been working flawlessly. For the production runs we're going to move the pots on the board over a little so they are easier to reach. But other than that it's ready to go.
I've got 3x pre-production units we want to get out for some extended testing. Will do them for $100 each shipped but there are conditions. You have to be willing to install it ASAP and provide us a little feedback!
Default 11-12-2019, 02:47 PM
It's dutycycle just like the factory EKP... So it allows you to run the pump at slower speeds if you want to avoid over heating it or adding more heat to the fuel by pushing it around the regulator.
Lowon's Avatar
Car: Bmw M2
Default 11-12-2019, 05:16 PM
Any updates on this function?
Mods: Stock for now
Gianttcr Gianttcr is offline
Car: 2008 E92 N54 FBO
Default 11-12-2019, 05:54 PM
Terry, just emailed you. DEFINITELY interested, if you've got units to spare. Thanks!
@BIMMERSRD12 @BIMMERSRD12 is offline
Car: Bmw 535xi e60
Default 11-12-2019, 10:46 PM
Terry i m want one please
evl335 evl335 is offline
Car: 335is
Default 11-15-2019, 06:59 AM
will this work along side with the a PI kit with hobbs switch and split second aic6 for mhd?
Default 11-15-2019, 11:34 AM
Yes, it will go in place of the hobbs switch basically.
Car: 335is
Default 11-15-2019, 12:07 PM
Are there any of the 3 left for sale? Can I please purchase PayPal? Thanks for the reply
Car: 335is
Default 11-15-2019, 12:08 PM
Happy to document install and review
Default 11-15-2019, 01:10 PM
Email Terry@burgertuning.com
Car: 2010 135i
Default 11-15-2019, 01:45 PM
I'll wait for a tested production unit. And car is still being built so I can't do anything right now neways.
But I'll be in the market for one probably.
2010 135i auto,
Default 11-21-2019, 01:50 PM
One more pre-production unit we want to get out to an E90 N54 or N55!
miksebik miksebik is offline
Default 11-25-2019, 01:28 PM
How I would love to help you, if there was not winter knocking on doors in Europe :-/ But definitely interested in the final product! With my LPFP collapsing to 40 in hot weather.. LOL.
E92 335i N54, Hexon RR500, JB4, DCI, MMP inlets, ER chargepipe, Turbosmart Kompact Dual Port BOV, ATM IC, Wagner downp*pes, MPerformance exhaust, oil cooler, trebila flash (via MHD Flasher), E60, M Performance 370mm brakes, styling 313 wheels, M Performance suspension, Fuelit Stage2, MFactory LSD, MFactory SMWF
