Can't set TMAP setting to 0 -
04-30-2019, 07:49 PM
I'm trying to leave JB4 connected but run in a stock mode. I've flashed MHD back to a stock map and set JB4 to map 0. I've set steering wheel mode 4-3.
I went out for a ride and it seemed to run ok. I went WOT and immediately got a half engine light. I thought that maybe it was because I've still had the N20 3.5 bar TMAP installed. So, I re-installed the stock sensor and was trying to set the TMAP setting to 0 but I get an error message: "Invalid values in user table. Fix and try again"
I can change it to a 1 or a 2, but not 0. Am I missing something?
At the moment, I re-installed the 3.5 bar sensor back in and with the engine not running but JB4 connected, my boost is reading 0.4psi. Not sure if that helps at all.
Make sure no boost setting value is > 20psi outside the factory sensor range.
