Car: BMW 135i M-Sport
N55 135i Multiple Misfires and Fuel-related Codes -
09-03-2018, 11:15 AM
Looking for some advice from my fellow N55 friends…
Experiencing multiple cylinder misfires and fuel codes - any insight on the most-likely root issue would be much appreciated.
2012 N55 135i M-Sport
Symptoms:
- long start
- rough idle
- white smoke from exhaust
- sometimes engine barely runs
- onboard computer shows fuel pump error but LPFP and HPFP have both been replaced
Codes:
- 2C90 Blow-Off valve mechanics -- Ignore, tuner code
- 2EFE Combustion misfires, several cylinders detected
- 2F03 Cylinder 5 Misfire Detected
- 2EE0 Combustion misfiring, several cylinders, fuel injection deactivation*
- 2EF1 Combustion misfiring, cylinder 5: Fuel injection deactivation
- 2F00 Cylinder 2 Misfire Detected
- 2EE7 Combustion misfiring, cylinder 2: Fuel injection deactivation
- 2F04 Cylinder 6 misfire
- 2EF4 Combustion misfiring, cylinder 6: Fuel injection deactivation
- 2F02 Cylinder 4 misfire
- 2EED Combustion misfiring, cylinder 4: Fuel injection deactivation
- 2C01 High pressure fuel system, fuel pressure: Minimum pressure undershot
- 2BF5 Rail pressure sensor, plausibility: Minimum pressure undershot
- 2EE2 Combustion misfiring, several cylinders: damaging exhaust gas after start sequence
- 2EF3 Combustion misfiring, cylinder 5: damaging exhaust gas after start sequence
- 2EF6 Combustion misfiring, cylinder 6: damaging exhaust gas after start sequence
Recent Changes:
- Replaced LPFP with Fuel-It Stage 2 LPFP
- Replace HPFP with OEM Remanufactured
Relevant Mods:
- BMS JB4
- BMS Cold Air Intake
- Evolution Racewerks Charge Pipe
- Fuel-It Stage 2 Low Pressure Fuel Pump
- DV+ Performance Diverter Valve
- NGK 5992 / 95770 1-Step Colder Plugs
Logs from today attached.
I am pretty new to this, so any help is greatly appreciated. Thank you!
Car: 2007 e60 5 series
09-03-2018, 06:19 PM
Looks like the ecu is under attack, don't change anymore parts until you can confirm the mosfets are not fried. The erratic misfiring is a dead giveaway.
Car: M135i
09-03-2018, 07:24 PM
Symptoms:
- long start
- rough idle
Codes:
Recent Changes:
Relevant Mods:
- BMS JB4
I do not see pressure from LPFP
M135i EWG 2014
[B] Pure Turbo Stage 2 | Port Injection FI | Exhaust |Chargepipe ER | Intercooler Phoenix | Intake BMS | LPFP Stage 2 FI | TMAP N20 3.5 BAR | Pure Inlet Highflow | GFB DV+ | JB4 | BEF Trebila
Hoosier
Your’s Erik🇲🇽
09-03-2018, 10:41 PM
No LPFP sensor
09-06-2018, 08:49 AM
I replaced the Fuel Pressure Sensor yesterday - no change.
So now I have a brand new LPFP from Fuel-It, a new OEM remanufactured HPFP, and a new Fuel Pressure Sensor.
The onboard computer still says the Fuel Pump is bad but the 2C01(High pressure fuel system, fuel pressure: Minimum pressure undershot) and 2BF5 (Rail pressure sensor, plausibility: Minimum pressure undershot) are gone.
The white smoke from the exhaust is now even more - a lot of white smoke that smells very strongly like gas - both idling and driving.
Where should I look next? Is it likely that one of the Fuel Pumps I replaced is bad?
What does the massive amount of white smoke that smells like gas tell us?
Current codes:
00F1
212F
03E0
60F1
222E
Car: M135i
09-06-2018, 09:13 AM
Current codes:
00F1
212F
03E0
60F1
222E
White smoke I do not think it's due to lack of fuel.
M135i EWG 2014
Hoosier
Your’s Erik🇲🇽
09-06-2018, 10:14 AM
Originally Posted by Dave @ Fuel-it!
No LPFP sensor
Dave,
The white smoke from the exhaust smells very strongly like gas - both idling and driving, lots of fuel coming through the exhaust.
09-06-2018, 10:19 AM
I had a similar issue on a customer's 135i. We changed the HPFP and then the car had the same issues as yours, car would misfire above 12 psi, the issue was a bad remanufactured HPFP, ordered a brand new one from my local dealer and issues gone!
webpage: bigboostusa.com
BigBoost's car: BMW M240i
Stage 3.4 turbo
Current B58 record holder: Currently: 822 WHP
4.8 100-200
10.85 @ 135 1/4 mile
Daily Driver: BMW M235i
BBT stage 3.3 turbo
09-08-2018, 07:33 AM
Update: Replaced HPFP again yesterday. No change.
Car: 2011 135i
12-21-2018, 05:40 AM
Was there ever a resolution to this? I'm having the exact same problem (same codes, same thick, white fuel-smelling smoke from the exhaust). I've replaced the HPFP and swapped plugs/coils around with no success.
Thread Tools |
Display Modes |
