andrew.g35.04@gmail.com andrew.g35.04@gmail.com is offline
Car: 335i 2009
Default Can someone look over my data logs for me would be greately appreciated - 12-30-2016, 04:13 PM
2009 335i
Dci
Intercooler
Chargepipe bov
Jb4+mhd e85 bef
Blackbeautyn54
Russell @ BMS's Avatar
Car: 2009 335i AT
Default 12-30-2016, 06:07 PM
You have an N54 and not a N55 correct? OEM N54 usually can maintain about 15 psi at high RPM so I do not know why your boost is falling off so much at high RPM.
It is unreasonable to expect the OEM turbo's to maintain 18 PSI at high RPM.
Car: 335i 2009
Default 12-30-2016, 06:31 PM
It's an n54 and I'm running the jb4 with the mhd back end flash any reason it could be dropping off like that I'm new to the platform!
Blackbeautyn54
Car: 2009 335i AT
Default 12-30-2016, 06:41 PM
Could be a boost leak.... insufficient vacuum in the vacuum storage canisters.... bad vacuum solenoid valve.
I would get a vacuum gauge and Tee it into the WG vacuum line.
You should see about 22 to 26 In Hg when at full throttle and high RPM.
Car: 335i 2009
Default 12-30-2016, 07:09 PM
Thank you guess I'll start checking all the above!
Blackbeautyn54
Ewilly096 Ewilly096 is offline
Car: 2008 335i 6mt
Default 12-30-2016, 07:44 PM
Can you guys take a look at my log? Should my throttle value be as wavy as it is? This is on map 1 but also occurs on map 5.
Car: 335i 2009
Default 01-01-2017, 07:04 PM
So I tested what you said and everything checked out anything else it could be?
Blackbeautyn54
Default 01-02-2017, 06:30 PM
You'll need to start your own thread and take a proper 3rd gear log for any input.
Default 01-02-2017, 06:31 PM
I'd agree....boost leak or turbos.
