jcy335xi's Avatar
jcy335xi jcy335xi is offline
Default Rough idle on cold start and trips SES light - 12-30-2016, 10:15 AM
For the past several mornings, my car has idling very rough at cold start up. If I blimp the throttle or hold the throttle at a higher rpm (above 1500), the slight shuddering goes away.
If I let it idle, it would ultimately trip a SES. Of all the times this occurs, I primarily at a 2A2B and 29E0, fuel mixture control faults. Occasionally, I get a 29CF Cylinder 3 misfire. Once the codes are cleared and the engine is warm, the SES/rough idle won't come back until the next cold start.
I've replaced the ignition coil within the last 9 months, plugs within the last year. Could this be a leaky injector?
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 12-30-2016, 10:27 AM
Injectors.
09 335 - 6266
07 335i - 6870, E85 - SOLD
Russell @ BMS's Avatar
Car: 2009 335i AT
Default 12-30-2016, 06:34 PM
Are you running any E85?
jcy335xi's Avatar
Default 01-01-2017, 06:22 PM
No, just pump. I got a 2C27 Lambda probe in front catalytic converter today as well. Maybe a bad O2?
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 01-02-2017, 09:34 AM
It would be nice if people with 'cold start' problems would tell us what temperature this is happening at. Engine requirements are very different from +70 degrees to -20 degrees.
Have you tried starting the car with the JB4 in bypass?
Totaled by a careless driver:
'08 E92 335, M sport option
Default 01-02-2017, 06:51 PM
N54? N55?
Got a log?
A bad O2 sensor would certainly contribute to that.
jcy335xi's Avatar
Default 01-04-2017, 08:39 PM
Currently, it's happens in both mid 40 and mid 20 degree temps. JB4 toggled to Map 0 has no impact.
jcy335xi's Avatar
Default 01-04-2017, 08:40 PM
N54? N55?
Got a log?
It's a N54. I read my codes again and the following came up:
2A2B Fuel Mixture Control
29E0 Fuel Mixture Control
2C27 Lambda probe in front of ***
Reset the code and connected the laptop to JB4. It took a couple tries to figure out how to log idle, I was able to log an occurrence where the rough idle was very pronounced. In the log, the RPMs dropped below 600 (time stamp 103 - 105). It didn't trip a SES but the idle was definitely rough. If needed, I can log tomorrow morning again before I go to work but this is pretty much what I experienced consistently the past couple of weeks.
Default 01-05-2017, 08:52 AM
That was an issue with bank 1. Once trims go to closed loop they bottom out and you run very rich.
You'll have to get to the bottom of that to resolve your issue. Maybe a bad injector, O2 sensor, exhaust leak, or ???
jcy335xi's Avatar
Default 01-05-2017, 09:38 AM
Thanks Steve. I'll have my indy shop replace my O2s while they are replacing my oil pan gasket since they are dropping the subframe already.
Default 01-05-2017, 09:59 AM
jcy335xi's Avatar
Default 02-07-2017, 06:15 PM
Attachment 59384
Replaced the Bank 1 o2 sensor and it seems to have fixed the issue. I'm no longer seeing the trims bottom out. Here is the latest idle log and settings via JB4 Interface. Are my settings acceptable?
Default 02-07-2017, 10:55 PM
Looks good and settings are correct.
jcy335xi's Avatar
Default 02-08-2017, 10:02 AM
Thanks again!
Default 02-08-2017, 06:21 PM
