B335T B335T is offline
Car: 2008 335i
Default WTB N54 Valve Cover - 11-29-2016, 08:14 AM
Recently went to change the gasket on my valve cover and noticed a small chip in the groove that holds the gasket. Went ahead and installed the new gasket in hoping that the gasket would seal the small chip, seeing as how small it was but unfortunately it is leaking from that exact spot. I've searched online for a Valve cover but everyone wants $400+ which seems a little high for a piece of hard plastic designed to crack. Dealership wants an arm and leg at $750. Thought I'd check with you all to see what was out there. Car is 08 335i N54. Also wanted to see if there is a better aftermarket solution? Thanks in advance!
trohde78's Avatar
trohde78 trohde78 is offline
Car: 2009 335i Coupe 6MT
Default 11-29-2016, 09:43 AM
They are very overpriced! I got mine from a BMW dealer on eBay during the summer for $360. Supposedly, the new ones were revised in some way and should not crack. Probably why they doubled in price over the past few years. haha!
Car: 2008 335i
Default 11-29-2016, 09:51 AM
It's crazy but I guess it is/was a good marketing decision to go with the hard plastic. I may even see about hitting up a few local junkyards to see what they have to offer. I've seen a few on ebay but am somewhat worrisome buying one from there. Easy to hide hairline fractures
trohde78's Avatar
Default 11-29-2016, 09:59 AM
I would advise against a used one, unless you don't plan on keeping the car much longer. I reused my cover after replacing the gasket, and it cracked within a month.
Car: 2008 335i
Default 11-29-2016, 10:05 AM
Thanks for the info. I'll definitely keep that in mind and avoid used.
Russell @ BMS's Avatar
Car: 2009 335i AT
Default 11-29-2016, 08:15 PM
Why don't you try a gasket sealer to glue your new gasket into your existing cover.
Or you could use JB Weld to repair your current cover.
Should be worth a shot considering how much a new cover costs.
Car: 2008 335i
Default 11-30-2016, 06:57 AM
I thought about it but my father was helping me when cleaning the valve cover and gasket surface area. He took the cover to blow out any debris with an air nozzle and that's when he noticed the small chip blow out. We searched for the small chip but couldn't find it. I thought about the jb weld idea also but was curious to if that would be a reasonable fix or if it may create more problems. I guess I could always sand it flat but was slightly worried about taking this route. What are y'alls thoughts?
Car: 2008 335i
Default 12-05-2016, 07:38 AM
I went ahead and bought a new one with gasket and bolts included on ECS Tuning for $379 to give myself peace of mind of not having to deal with a used one being warped or leaking. Thanks to everyone for the input and info!
