harkes harkes is offline
Registered Users
Car: M135i
Exclamation Trims not working and running lean - 11-22-2016, 10:48 PM
Hi chaps
What the hell happened here? Looks like trims are not working and I go lean until they wake up Is this a FW bug??? What would have happened if this was map6 or map3 in kill mode?
FW: ISO_4
Mods: See my signature
Registered Users
Car: M135i
Default 11-23-2016, 03:50 PM
Terry
I'd really like to know what you think about this? I get scared seeing a log like this...
Russell @ BMS's Avatar
Car: 2009 335i AT
Default 11-23-2016, 04:20 PM
Have you been running map 8 and now are running map 4?
Registered Users
Car: M135i
Default 11-23-2016, 05:54 PM
Not heard of map8 before and never run it.
Default 11-23-2016, 05:58 PM
Trims = 25 mean you are stuck in open loop fuel mode. Normally caused by an o2 sensor fault or some issue with the o2 sensor.
Registered Users
Car: M135i
Default 11-23-2016, 07:39 PM
Should I not be getting an error code for that? You have now moved lean protection down to 3500rpm for ISO_5 but at what AFR does it kick in? Will it save my engine if this occurs again?
Default 11-23-2016, 08:32 PM
With that ISO F series firmware lean run would kick in over 3500rpm AFR leaner than 15:1, for more than a second.
Registered Users
Car: M135i
Default 11-23-2016, 08:47 PM
If car went into open loop would I not get an error code for that?
Default 11-23-2016, 08:57 PM
No the DME won't throw an error for sticking in open loop fueling mode. It's pretty dumb like that.
Registered Users
Car: M135i
Default 11-23-2016, 11:51 PM
Did some more DB tuning and forgot about the "open loop issue". My mistake, but why does the lean protection not work from zero rpm???
This is map3 with all the JB4 nannies at work - I wouldn't expect something like this to be possible...
Yes, I know my trims are maxed out - already increased FOL.
Registered Users
Car: M135i
Default 11-25-2016, 05:33 PM
BUMP.... Can someone help me with some answers?
Car: 2009 335i AT
Default 11-25-2016, 06:25 PM
It would help if you did not start the run from a zero pedal position. Run for at least 5 seconds to allow the AFR to get back in range from the coasting period before going WOT. This should not be necessary when ECU learns to up the fuel and if within range of fuel trims and FOL.
Registered Users
Car: M135i
Default 11-26-2016, 04:24 AM
I have been doing hundreds of pulls like this, so why does it not work anymore? Is it an O2 sensor problem or a JB4 problem? It would be nice to drive the car without have to worry if I break it.
