Free MHD M-Boost Maps (standalone OR stacked) -
08-17-2015, 10:24 AM
https://www.dropbox.com/sh/gso843e48...61s7McCva?dl=0
spxtuning@gmail - If you email me for custom stuff - please include DME, fuel, mods, etc
Car: BMW E92 335i
08-17-2015, 11:12 AM
Originally Posted by Spxxx
08-17-2015, 12:53 PM
Thank you!
Can you please specify target boost etc?
Mike
E92 335i N54, Hexon RR500, JB4, DCI, MMP inlets, ER chargepipe, Turbosmart Kompact Dual Port BOV, ATM IC, Wagner downp*pes, MPerformance exhaust, oil cooler, trebila flash (via MHD Flasher), E60, M Performance 370mm brakes, styling 313 wheels, M Performance suspension, Fuelit Stage2, MFactory LSD, MFactory SMWF
Car: N54
08-17-2015, 04:50 PM
I did a while ago and you didn't reply
Certified Australian 335i N54 2009 DCT | JB4 | FBO | E85
08-17-2015, 05:29 PM
It's because I hate you... duh.
Just bug me, I usually get back after email number 2 or 3 haha sorry I am swamped at work. My pump flashes suck balls and are still having the kinks worked out if that's what your email was regards to.
08-17-2015, 07:27 PM
any chance you might make a e50 map?
08-17-2015, 07:41 PM
Yeah, the difference between e50 and e60 is minimal.
Send logs of the e60 map with e50 (by volume).... Or you can wait, I'll post an e50 at some point but it won't be that much different than the e60 that is already posted.
Car: 09 BMW 335i
08-18-2015, 08:18 AM
Hello, thank you for sharing . Will try it out and post some logs. But first got to find how to completely turn off jb4.
08-18-2015, 09:59 AM
Just keep the JB4 and stack it, that's what I do... great combo.
Car: 2007 BMW 335xi 6AT
08-18-2015, 10:02 AM
Will these maps work with Cobb ap3 or are they MHD specific?
Car: 09 BMW 335i
08-18-2015, 10:39 AM
Great! Will try it !
08-18-2015, 11:15 AM
Do you have these same maps w/o the MBoost option? I don't have the n20 map sensor, and am not sure if I will ever install one.
Car: 09 BMW 335i
08-18-2015, 11:47 AM
So we need n20tmap and obtain mboost license in order to run thous maps? Is that correct?
Car: 2010 135i 6MT
08-18-2015, 12:02 PM
You don't need an N20 sensor for these. Just the M-Boost option. There is a difference between M-Boost (allows up to 21-22psi via flash only, race-logic), and MaxBoost (device plugs between N20 sensor and DME), which allows up to 36psi. That involves scaling, and there are no OTS maps for it. Those maps should be custom tuned to your specific setup.
Enjoying the new tables discovered and the XDF progress made?  if you'd like. Every bit is appreciated!
Car: 09 BMW 335i
08-18-2015, 12:18 PM
So why do we need jb4 if boost control goes to flash side, I guess . Safety futures and loging only? So we need to do 4/2 on jb4? Sorry if that's a noob question !!
Car: 335is DCT
08-18-2015, 12:36 PM
So why do we need jb4 if boost control goes to flash side, I guess . Safety futures and loging only? So we need to do 4/4 on jb4? Sorry if that's a noob question !!
You don't need a JB4 if you want to run MHD standalone flash maps.
08-18-2015, 01:01 PM
Ok, pardon my ignorance as I must have missed this whole MHD MBoost subject entirely. Thank you for clarifying MBoost is not a truncated reference to MaxBoost, as I assumed it was.
Is MBoost an add-on to MHD that needs to be purchased? Other than the 21-22 PSI control, are we getting anything else with this function?
Car: 335is DCT
08-18-2015, 01:14 PM
The whole Mboost/Maxboost naming is a mess. Leads to way too much confusion. Mboost is a module that you purchase in MHD. Think of it as Race code for MHD, much like Cobb had. It allows I8A0S and IJE0S usesrs to raise the boost ceiling from 1.28 bar to 1.50 bar so you can tune beyond 18.5 psi. N20 Tmap isnt required but recommended if you are going to be pushing the stock Tmap to the edge of its voltage range.
Maxboost is the physical device you purchase from Wedge. It replaces the N20 adapter but you still have to purchase an N20 Tmap to use it. It scales voltage beyond 10 psi to allow up to 27-36psi depending on your ROM version. As Jake mentioned the OTS maps do not support this and will require custom tuning.
08-18-2015, 01:19 PM
Awesome, thanks again for clarifying MUSC.
So, just to confirm we'll be safe with these maps w/o the TMAP? I was going to try the E30 later this week.
08-18-2015, 01:23 PM
Yeah stock TMAP is fine for e30/40... And probably the e50/60 but you'll be close to the stock TMAP ceiling with those and therefore it's suggested but up to you.
08-18-2015, 01:37 PM
Sweet! By the way, this is N54Door from e90.
08-18-2015, 01:58 PM
Thnx for the support
08-19-2015, 07:16 AM
Anyone?
Car: 335is DCT
08-19-2015, 07:38 AM
Anyone?
They are for MHD
08-19-2015, 07:39 AM
Anyone?
The title kinda gives it away. You can port them over using Tuner pro but that's a tedious process
Thread Tools |
Display Modes |
