Acetech Acetech is offline
Car: 03 M3. 98 M3. 11 1M?
Default Fast spooling single ??? - 08-11-2015, 07:23 PM
If I do a single I want fast spool fast response, no need for more than 600 wheel, preference for bottom mount though no twin scroll manis exist in bottom mount. May not be a big deal.
I found Terry ran a 5862 turbo and remarked it was great for street and spool.
What recommendations do people have? Can a small single match the spool and response of current hybrid twins?
Car: 2007 e90 335i
Default 08-12-2015, 02:22 AM
The best 600whp turbo is a t3 garrett gtx3576r with a .63 ar hot side.
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 08-12-2015, 03:16 AM
If you're only after 600whp and are concerned with spool you might as well stick with twins (hybrid RB's, VTT's or Pure) + inlets.
2016 F22 M240i | 8ZF
boost junkie boost junkie is offline
Car: bmw
Default 08-12-2015, 05:38 AM
For a lot less $ too.
Default 08-12-2015, 05:45 AM
All good things to consider.
Pros of the single are lower octain requirement and more reliable turbo, negative are cost 1-2 thousand more and there is not a lot of info about people that have done a smaller single and how it performs.
The pros of twins are, you know how they perform and they are a bit cheaper, cons, octane requirement, rediculase wait time for them to be made (my biggest complaint), reliability 20000 miles if your lucky.
N54 TuNeR's Avatar
N54 TuNeR N54 TuNeR is offline
Cool ///Member
Car: E90 SEDAN
Default 08-12-2015, 10:16 AM
If your auto,Single turbo has lower torque then twins which would be better on your trans.
SOLD
2004 E46 ///M3 MODDED
PRESENT RiDE
2008 E90 SEDAN G5 iSO-FBO FSB-100%METH-DUAL NOZZLES,Fuel iT!Stage 2
csu87 csu87 is offline
Car: 09 335xi
Default 08-12-2015, 11:12 AM
just find a small turbo and slap it on. think GTX30xx and lower sized turbos
Default 08-12-2015, 11:43 AM
If the Steedspeed mani is finished anytime soon I just may
Default 08-12-2015, 12:27 PM
The MOTIV 750 kit spools nicely and is worth a look. Alternatively most of the 5858 kits spool OK. A VM 5862 would be nice too. But if 600whp is all you want the OEM twins are probably a wiser choice.
The Leopard's Avatar
Car: E92
Default 08-12-2015, 06:43 PM
A GT30R (or any GTX30) makes around the same power as stock turbos with inlets. IMO, you need something bigger to justify all of the hassle and expense of going single.
TS N54
Vertigo's Avatar
Vertigo Vertigo is offline
Car: AW 335i
Default 08-13-2015, 06:16 AM
You know how ridiculously spoiled we sound saying "only 600whp". I just think back to the old days with my LS1 and what we had to do just to get to 450.
2008 335i stock
wtfmarine's Avatar
wtfmarine wtfmarine is offline
Car: 2007 BMW 335i
Default 08-16-2015, 09:23 AM
I run a 5858 and push about 530~ to the ground. I'm happy with it. The pros are reliability over stock turbos. I've had zero issues outside my own screw ups on installing/tuning. I spool around 3200 rpms. I dont post a lot about my car because of there is not much to say lol. I am fabricating a new intake for the turbo and a new engine cover for bling factor. A meth kit, oil cooler (hell yeah I am still running no oil cooler) and other odd stuff. Oh my cup holder stopped popping out of the dash. I'm still trying to figure out how to fix that...
07 335i sleeper - PT5858 single turbo - stock exhaust - stock wheels
Default 08-16-2015, 02:55 PM
Nice, what PSI do you run to get 530 wheel and is it maxed out?
I found a thread about CES motorsport running a gtx35R on a E36 with a TS steedspeed mani with very good spool and 700 wheel at 26 psi
http://www.bimmerforums.com/forum/sh...t-GTX35R/page3
BoostAddict BoostAddict is offline
Car: e46 323i/ 04.5 Turbo 350Z
Default 08-16-2015, 04:11 PM
That car has headwork and cams. Probably not the best comparison.
www.BoostAddictions.com
Custom Engine Calibrations and Performance Parts
996 Turbo
Default 08-17-2015, 06:42 AM
They are not apples to apples but they are very close in design and displacement, plus I would think cams and head work would improve top end not spool. And the N54 higher CR and dual vanos and direct injection would all be benifical to some degree for spool and width of power band compaired to the M52.
Taron's Avatar
Taron Taron is offline
Car: 2008 BMW 335XI
Default 08-17-2015, 03:25 PM
Terry there is 600whp car with oem twins? Even rbs are not able to produce such power and keep working, am i wrong?
k8R8k k8R8k is offline
Car: BMW
Default 10-14-2015, 04:26 AM
Has anyone made 600whp with the GTX3576R on the N54?
I can't seem to find much/any information on it.
Van3 Van3 is offline
Car: Bimmer
Default 10-14-2015, 09:59 AM
A T3 would be a horrible idea for this car.
Default 10-14-2015, 10:14 AM
OEM twins that have been modified. e.g. PURE, RB, Vargas, etc.
tc535i tc535i is offline
Car: 95 M3, 01 330i, 07 335i
Default 10-14-2015, 10:17 AM
can you explain why this is? you'd think two turbos are more expensive than one, you're still replacing manifold etc so no difference there... just the custom work to convert to single makes it more? what am I not getting... do turbos become exponentially more expensive as they get bigger?
natedog7700's Avatar
Car: 2007 bmw 335i e90 auto
Default 10-14-2015, 10:42 AM
LS1s still put in work... Slap a turbo on it for a few grand and its pushing more than my car. No replacement for displacement.
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
