(#1501)
NeoN's Avatar
NeoN NeoN is offline
Car: 2011 335i X Drive
Default 09-15-2014, 07:30 AM
Any word on android availability? Went to the website to buy mine and I saw this.
Current status: Awaiting Parts
Current wait time: 2 Months 1 Day
is that so? I am waiting to pay, ready whenever!
2018 C43 AMG Black/Black
JB1 Map 2
Full 20% Tints All-Around
Custom Front-License Plate
Check my YouTube [https://www.youtube.com/channel/UC8K...as=subscriber] Channel for more
(#1502)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 09-15-2014, 09:55 AM
Originally Posted by cebrailbakan
after I update the firmware to 28.3hex , I couldn't connect to Jb4 via my laptop. I did everything , in fact I bought a new laptop , then I asked a laptop from my friend , I controlled everything I know it very well how to be connected for three years , the computer saw the usb serial port but can't connect , what is wrong Friends? If usb cable failed how it is seen usb serial com port 3 ??
Replied via email.
Sadly right now that is how long the wait is. Expect the wait time to go down again as soon as I get some more parts in because I will be cranking out the kits.
(#1503)
NeoN's Avatar
Default 09-15-2014, 10:52 AM
Originally Posted by dmacpro91
Replied via email.
No problem! I'll be here, i saw my friend has it and i loved the capabilities...pretty sick! Eager and ready to test it out!
JB1 Map 2
(#1504)
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 09-15-2014, 04:03 PM
Originally Posted by BOOST_WILLIS
So when u saw the driver in your divorce manager it said com port 3? Because once you see what port you have on your device manager in reference to jb4 I.e. Com port 5 then you type in com port 5 in your jb4 settings. And it should connect.
when I plug usb , I went to device manager it has seen usb serial port com 3; then go to Jb4 setting and wrote 3 there , but after a seconds it says connection failed com 3
Dmacpro I didn't receive your mail , please send it again
(#1505)
Car: 2008 135i
Default 09-15-2014, 06:11 PM
Sorry I thought you were someone else.
Sounds like you are using the Windows interface. Is that correct?
(#1506)
Car: BMW E90 335XI
Default 09-15-2014, 09:42 PM
Yes sir , it is Windows.
(#1507)
Car: 2008 135i
Default 09-16-2014, 02:06 PM
You will need to refer to the appropriate thread for Windows support.
For Android users, one of my friends is going to let me use his Note for a bit tonight so I can test on that and see what is going on with those devices.
(#1508)
Car: 2008 135i
Default 09-16-2014, 03:29 PM
For iOS users, iOS 8 comes out tomorrow. I am putting the finishing touches on my app for it and will be uploading it hopefully tonight so it should be live in the next week. I'm getting my iPhone 6 on Friday and will be optimizing the app for that the following week.
(#1509)
rleroy4298 rleroy4298 is offline
Default 09-16-2014, 10:12 PM
OK so this has probably been brought up before, but is there no way at all to setup a direct connection from the JB4 USB cable to an iPhone or iPad (of course with a connection interface as we all know these devices don't have a USB outlet) and then purchase the app? I feel like there must be a way and the only reason I ask is that the wiring wouldn't bother me personally and I would want to get this setup now/soon and know there's a 1-2 month wait list for the Bluetooth option. Thanks for any insight on this!
(#1510)
ba114's Avatar
ba114 ba114 is offline
Car: 135i 6MT
Default 09-16-2014, 11:51 PM
to my knowledge iPhones can accept and interpret serial connections (software required). A physical cable *may* be able to connect to the jb4 usb via a cable with a PL2303x or FT232 USB-to-Serial chip.
From memory Pins 12 & 13 are the Tx an Rx on an dock connector.
I guess it just comes down to whether dmacpro91 can make it work on the software side.
(#1511)
Car: 2008 135i
Default 09-17-2014, 04:34 AM
Not going to happen for quite a few reasons.
1) My app would be rejected from the App Store for trying to use the dock connecter in an unauthorized way.
2) You *might* be able to get it to work with those old 30-pin connectors and a jailbroken device, but phones with those connectors aren't being made anymore and requiring a jailbreak is just too much to ask.
As I said in the first post, I've looked into other options, but this is all that works.
(#1512)
Car: 2008 135i
Default 09-17-2014, 11:18 PM
Update from my tests with Galaxy Notes:
I tested the app on 2 Notes yesterday (a Note 2 and a Note 3, both on 4.4.2). Everything worked flawlessly. I tried pulling the cable out while logging and everything and the app still did everything it was supposed to do and connected the first time, every time. So I can't figure out why some of you are having issues with connecting. Maybe it's an older OS on your device or maybe it is your OTG cable, idk. Just wanted to let everybody know my results. I have videos of the tests I might upload later, but it's not that interesting.
(#1513)
Jeff_335i Jeff_335i is offline
Car: 2007 E92 335i
Default 09-18-2014, 01:35 PM
Took the car to the dragstrip last night, ran into a few problems. First time I've used JB4 Mobile since updating to version A033 (Android) from a release that was maybe 3 versions old. The interim updates were installed on my phone as they were released on Google Play, but I did not drive my car during that period of time. I'm also a beta tester for Android Bluetooth. Everything worked fine with (I think) version A029 using the OTG cable but was sometimes flaky with the Bluetooth connection. We had talked about that via e-mail previously.
Last night I did 8 runs at the dragstrip, and every single time the app crashed before the end of the run. I did 4 runs using Bluetooth and 4 runs using the OTG cable. Only one time did it ask to send a crash report, which I did. The other times I had to reboot my phone to get it working again. I had Wi-Fi disabled the whole time. The Bluetooth connection worked fine for the 1 hour drive to the track. Using previous versions of the software, when driving my car on a road race course I had to use OTG for the connection since Bluetooth always failed. Now neither connection type works reliably. They both seem to work fine under normal street driving conditions, but as soon as I really start hammering it things go badly.
Hope that makes sense, let me know if you have any suggestions or need more info.
2007 E92 335i | JB4 G5 ISO | BMS MHD Backend Flash | JB4 Mobile | Alpina TCU Flash | ETS FMIC | aFe DCI | BMS OCC | ER Chargepipe | Corsa exhaust | ISC Coilovers | APEX ARC-8 Wheels | Stoptech Trophy BBK ST60/40 | Dinan oil cooler
(#1514)
Car: 2008 135i
Default 09-18-2014, 02:23 PM
I found your crash report and will release an update later today for that.
As for Bluetooth, that's just an Android thing. Sometimes the bluetooth stack crashes then you have to turn off both bluetooth and wifi to restart it. Sometimes even that doesn't work. I noticed this issue on the Note 3 I was testing. OTG worked great, but bluetooth would only connect the first time, then you had to restart the bluetooth stack after that. Hopefully the Android team will make their bluetooth stack more stable in the future. I'm going to include some kind of disclaimer in my emails so Android users who get my Bluetooth kit know of these issues.
(#1515)
Car: 2007 E92 335i
Default 09-18-2014, 02:41 PM
Thanks! I'm glad the crash reports are useful and will continue sending them whenever possible.
I'll be doing my last track weekend for the year in two weeks, so will have one last change to flog it before winter.
(#1516)
chatz86's Avatar
chatz86 chatz86 is offline
Car: 08 E92 335i N54
Default 09-19-2014, 03:22 PM
Does the Adroid app have the other gauge type option as IOS with the bars as opposed to the dials?
(#1517)
s0urce s0urce is offline
Car: 08' 335i 6MT JB4
Default 09-19-2014, 03:25 PM
I've still never been able to get the 0-60 time working.
Can you provide some clear, definitive instructions on doing so?
My process was:
Keep car at complete standstill
Recalibrate G-Force Meter
WOT Pull to 60
Check 0-60 results...nothing there.
Help!
(#1518)
Bullitt1841's Avatar
Default 09-19-2014, 07:07 PM
My process was:
WOT Pull to 60
Help!
To help dmac out, I would read the first post on how to describe your setup and your problem.
To help you out, is your GPS turned on? I had that problem on my tablet.
(#1519)
jleal1555 jleal1555 is offline
Car: 08 335i Sedan
Default 09-19-2014, 07:08 PM
My process was:
WOT Pull to 60
Help!
Go past 60
(#1520)
bmwsf bmwsf is offline
Car: bmw 335i
Default connectBlue - 09-19-2014, 09:16 PM
Are you using the connectBlue Bluetooth low energy platform module OLP425? I am curious what is the battery life of the bluetooth system. Will it last 1 year or longer? Thanks.
2008 BMW 335i | JB4 G5 | BMS Pump Flash | 3" n54Tuning *** | 3" ER Charge Pipe | 5" ETS FMIC
(#1521)
Car: 2008 135i
Default 09-20-2014, 10:06 AM
Not yet.
My process was:
WOT Pull to 60
Help!
I wrote the basic write-up in the first post.
No I'm not. Mine doesn't use a battery. It connects to a 5V source from the car for power.
(#1522)
Randy7fx's Avatar
Randy7fx Randy7fx is offline
Car: X1
Default 09-20-2014, 11:22 AM
Are there any significant changes/additions for iOS8 or iPhone 6?
(#1523)
Default 09-21-2014, 03:36 PM
My process was:
WOT Pull to 60
Help!
Using android with the OTG cable. GPS is on, the GPS speed variable has a value when moving. I've gone over 60mph from 0.
(#1524)
Default 09-21-2014, 08:33 PM
Yeah it actually doesn't work for me either. I've never been able to get it to work (completely). Seems to not even register that you've gone past 60 on my device. Several versions ago, I was able to get a time. But it was way off.
Honestly, I just use Torque with my external Bluetooth GPS. It works every time and is very consistent (it's 10 hz . Since dmac says it's still a work in progress, I didn't really care about complaining. I've actually tried it side by side with my android phone and tablet running simultaneously.
(#1525)
chatz86's Avatar
Default 09-22-2014, 04:13 AM
Hey has anyone had issues with the app freezing on all readings when not on throttle and only displays correct readings after getting on throttle again? I haven't been home to use Mt car for a week and I've noticed a couple of updates so I don't know If it's been resolved.
Closed Thread
