(#276)
Bme30's Avatar
Bme30 Bme30 is offline
Car: 07 335i 6 speed
Default 12-11-2013, 09:27 PM
No I havnt. I tried on 1.0.4. This was 2 days ago.
(#277)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 12-12-2013, 02:34 PM
Originally Posted by musc
Did you use version 1.0.5? I see the first posted is updated with that version but I haven't tried it yet. Still on 1.0.4.
1.0.5 probably won't fix the issue since I haven't been able to find the problem piece of code yet.
(#278)
BTMFR's Avatar
BTMFR BTMFR is offline
Default 12-12-2013, 03:27 PM
I just want to say that i have been wanting someone to do this for years thanks alot
(#279)
Car: 2008 135i
Default 12-12-2013, 06:02 PM
I may have found the issue with updating firmware!! I'll be testing it out tonight. If it works 3 times in a row, I'll post a new update for you all.
(#280)
Car: 2008 135i
Default 12-12-2013, 06:03 PM
No problem.
(#281)
Car: 2008 135i
Default 12-12-2013, 07:42 PM
Another JB4 app demo. Graphing and User settings.
(#282)
Car: 2008 135i
Default 12-13-2013, 12:06 AM
Still no luck with the firmware updating... Hopefully I can get a little help from the BMS guys.
(#283)
Car: 2008 135i
Default 12-13-2013, 12:58 AM
Just wanted to update everyone on the software/hardware iOS app situation. For starters the Mac app is going to remain free for everyone. As far as the iOS app goes, if you buy the hardware from me, the software will be free, if you want to make it yourself, the app will be $20.
(#284)
TYC's Avatar
TYC TYC is offline
Car: X1 n20
Default 12-13-2013, 09:02 AM
Great news. When can we start ordering the complete kit built by you? Can I also get the USB extension put on ahead of time, please?
(#285)
drace1 drace1 is offline
Car: 135i / Evo VIII
Default 12-13-2013, 07:01 PM
First off, thank you for taking the time to design this for the community it was much needed!
I have a BMW 1M w/ JB4 G5 ISO & BMS Backend Flash via COBB Accessport.
I upgraded to the newest Maverick OSX on my 2008 MacBook Pro & installed the linked USB Drivers 10_4-1_7
The JB4 OSX Program starts fine and loads. My MacBook gives me the Driver Activation Notice that I have connected the JB4 via USB.
When i try to connect the JB4 to the APP through the File area or by pressing "C" the APP remains "disconnected"
Any info on this - I'm trying to send some logs out
Car: 2008 135i
Default 12-13-2013, 07:21 PM
Make sure you goto settings and select the correct serial port from the drop down menu. Then just to be safe click file->connect.
(#287)
Car: 2008 135i
Default 12-13-2013, 07:30 PM
Very soon. I have a few different enclosures coming in this weekend because the last ones i ordered weren't the right size. If these work, then I will have a 100% complete parts list. I will will be selling these in small batches starting out, then after I sell a few, I'll ramp up production.
As for the usb extension, you could just order a cheap usb extension cord off of amazon, you wouldn't need one from me. I'll try to post some better pics of the whole setup so everyone can see what is included in the kit.
(#288)
Car: 2008 135i
Default 12-15-2013, 11:05 PM
Update about JB4 iOS Connect Kits in the first post.
Got some help from Terry pertaining to the firmware updating for the Mac app, so I'll try to have something worked out with that very soon.
(#289)
TYC's Avatar
TYC TYC is offline
Car: X1 n20
Default 12-16-2013, 10:27 AM
I was under the impresison that a standard usb extrneion cable is not supposed to be used according to the burger website??
can anyone confirm if any standard usb extension will work?
(#290)
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 12-16-2013, 06:43 PM
If you have the Burger USB cable, a standard USB cable can be used to extend the Burger USB cable.
(#291)
Car: 2008 135i
Default 12-17-2013, 03:34 PM
Just updated the Mac app to address firmware uploads. I've tested multiple times and everything worked for me, so try it out and let me know. Thanks again Terry, the issue ended up being updating the write status from the wrong thread causing a write timeout.
Edit:
Also note I've set my upload timeout to 5 to make the firmware uploads faster and everything has been fine.
(#292)
Bme30's Avatar
Default 12-17-2013, 04:32 PM
Edit:
AWEsoME!!! Thanks.
So who is going to try this first???
(#293)
MuNky6913's Avatar
MuNky6913 MuNky6913 is offline
Default 12-18-2013, 01:27 PM
damn, should of jumped on this when it was still $80. oh well.
2009 135i - Berk Tech. Race Axleback - Injen Short Ram Intake - BMS JB4 G5 ISO - CXRacing FMIC - ER Chargpipe - BMS Straight Down ***** - Walboro Inline Fuel Pump - Spec Stage 2+ Clutch - Spec SMFW - BMS Dual Meth Kit - BMS Backend Flash
(#294)
alexim's Avatar
alexim alexim is offline
Car: 1M
Default 12-19-2013, 04:57 AM
I'll try it!!!
(#295)
Car: 2008 135i
Default 12-19-2013, 04:09 PM
Here are some images of the kit.
JB4 data cable
USB cable end
BLE cable end
(#296)
jtrejo jtrejo is offline
Car: 535 2008
Default 12-19-2013, 04:11 PM
when can we purchase?
2015 535 - JB4 - VRSF pipe- Burger Intake - Straight piped - MHD Backend Flash
(#297)
Car: 2008 135i
Default 12-19-2013, 04:46 PM
Just made an update to the first post.
(#298)
Car: 2008 135i
Default 12-21-2013, 09:08 AM
Can anyone else verify that the firmware uploading is all good now?
(#299)
MuNky6913's Avatar
Default 12-21-2013, 09:21 AM
Would this app work with an adapter to just plug in the USB coming from the jb4 into the iPhone? Just using the app without having it wireless?
(#300)
Car: 2008 135i
Default 12-21-2013, 10:41 AM
Nope. Apple is VERY restrictive with an iOS device's usb access. That's why I had to go the wireless route.
Closed Thread
