(#76)
Russell @ BMS's Avatar
Car: 2009 335i AT
Default 05-24-2014, 06:32 PM
+1^
Artial is correct. This post: http://www.n54tech.com/forums/showthread.php?t=24991
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 05-30-2014, 05:16 PM
help?
i just installed RBs, spec clutch with steel single mass fw.
car feels slower than before i had the RBs... can someone help me out.
running full e85 with 455 in tank. dual cm5 nozzles at 75 additive.
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
Car: 2009 335i AT
Cool 05-30-2014, 06:55 PM
Originally Posted by frmtl2_335i
help?
Start a new thread in the support section.... not in this Sticky.... and also include the csv files. Also include all info listed in this Sticky:
JustinCredibleM's Avatar
JustinCredibleM JustinCredibleM is offline
Car: M235i
Default 06-02-2014, 08:36 PM
Hey Russell,
I noticed the N55 EWG cars run leaner than the pneumatic solenoid cars - do you know the reason? Could you also update the front page to show what AFRs to look out for so us EWG can have a better idea when looking at logs?
Car: 2009 335i AT
Default 06-03-2014, 10:45 AM
I believe the OEM DME's on newer cars are staying lean over a wider power band to help mileage..... but just a guess. Staying under 15:1 after tip in mid power band is starting to be the norm. If it was really too lean it would knock or miss. DI is a different world. JMHO
Chaddy74's Avatar
Chaddy74 Chaddy74 is offline
Car: M135i
Default 06-03-2014, 10:50 AM
how is the jb4 reading arf ? wouldn't the factory ecu be using lamda ?
M135I ER Down-pipe & charge pipe ,Milltek full system,Wagner Performance Intercooler AFE Stage 2 Intake Pure stage 1 Turbo & Quaife LSD
Car: 2009 335i AT
Default 06-03-2014, 11:01 AM
Yes the probe is a wideband sensor and reads lamda. Most cars run gasoline so lamda is multiplied by 14.7 to get AFR. Cars running 100% E85 are not running anything near 13:1 AFR @ WOT but for the sake of consistent indication..... that is what is displayed. No correction is being applied for fuel mix.
Chaddy74's Avatar
Car: M135i
Default 06-03-2014, 11:08 AM
that makes perfect sense especially the bit about ethanol and fuel mix , i was wondering how the jb4 and factory ecu was converting on the fly for different fuel grades. cheers
Car: M235i
Default 06-03-2014, 03:36 PM
So does that mean the ECU reading E35 is not really the correct E35 AFR? If so, how can we determine the actual AFR for safety?
laurean bmw 135i n54's Avatar
laurean bmw 135i n54 laurean bmw 135i n54 is offline
Car: bmw 135i n54
Default query - 06-03-2014, 06:39 PM
hello good guys want to give me a review of this map have rb turbos and other items purchased in burger Attachment 20614
Car: bmw 135i n54
Default 06-03-2014, 06:40 PM
I do not understand the 50 percent mark meth could someone explain me?
Car: 2009 335i AT
Cool 06-03-2014, 07:45 PM
Goggle Lamda and AFR.
There are many good articles on the subject, however, it is a little too involved to explain here in a few sentences.
You will have to trust me when I say that the AFR readings in the 12 to 15 range typically seen here (irregardless of type of fuel) are safe on any fuel mix........ but are only 100% correct when running on 100% gasoline.
Also See:
http://en.wikipedia.org/wiki/Air%E2%80%93fuel_ratio
Car: bmw 135i n54
Default 06-03-2014, 07:52 PM
Attachment 20617
Also See:
russell you think of my logs? Attachment 20617
Car: 2009 335i AT
Cool 06-03-2014, 08:22 PM
I assume you are running a BMS supplied meth system. Your "Meth Flow Scaling" value should be set to 60. Yours is set at 45???
Are you running with a single meth nozzle or multiple nozzles?
I am seeing a 21 degree drop in IAT so you are spraying something.
Has the current meth system ever indicated 100 flow in the past?
Your Map 6 is very aggressive since you are raising boost setpoint continuously as RPM rises over the whole rpm range.
Also your Avg Ign value is not staying below 1.5.
You had a knock event at max rpm and boost..... which is not good.
Car: M235i
Default 06-03-2014, 10:13 PM
Thank you, Russell. That clarified a lot.
Car: M235i
Default 06-06-2014, 01:03 AM
Hey Russell,
For some reason my JB4 changed from AutoShiftDamper 15 to 0 on its own. Do you know why it would do this and what this is for? I have an N55+EWG car.
Car: 2009 335i AT
Cool 06-06-2014, 09:59 AM
Hey Russell,
Auto Shift Damper adjusts the amount of PWM reduction during upshifts with cars with automatic transmissions.
I have no idea how your value got changed.
Car: M235i
Default 06-06-2014, 12:20 PM
Should I just put it back to 15 for the F-chassis?
EuroprojektzF30 EuroprojektzF30 is offline
Car: '14 335i EBII MSport
Default 06-17-2014, 08:15 PM
I want to experiment with E85 mixtures, but wanted to see where in the logs I can monitor my FP_H Levels? I do not see it on the graph, but see it in the program. I know if it goes below 11, then that's where its basically maxed out...but I want to know where I need to be looking to monitor this. Thanks.
Car: 2009 335i AT
Default 06-18-2014, 12:38 PM
Default 06-18-2014, 02:15 PM
My apologies for the double post
Michael1972 Michael1972 is offline
Car: 2007 BMW 335i
Default 06-19-2014, 10:37 AM
I need a little help. I seem to be maxing out at about 14.5-15psi boost on map 5. If I bumped up the boost values a pound or two in the user settings would that actually raise my boost? I am currently running JB4 g5 iso,VRSF *********, ER chargepipe Tial blow off valve, BMS dual cone intakes,Cyba scoops and 35% e85.
Car: 2009 335i AT
Cool 06-19-2014, 10:58 AM
Post all car related info and logs in your own original post in the help section.
Car: 2007 BMW 335i
Default 06-19-2014, 11:50 AM
I was directed her by Terry and thought this was the help section.
Car: 2009 335i AT
Default 06-19-2014, 07:27 PM
This whole page is the help section. You posted in a post on how to read logs.
Go here and open a new thread:
http://www.n54tech.com/forums/forumdisplay.php?f=35
