(#226)
Bullitt1841's Avatar
Default 01-14-2018, 10:26 AM
Logs need to be posted here: http://www.n54tech.com/forums/forumdisplay.php?f=35
wladimero wladimero is offline
Car: bmw 535xi
Default 02-17-2018, 02:09 PM
blindguyn54 blindguyn54 is offline
Car: 08 335xi coupe
Default 04-02-2018, 12:07 PM
I just started monitoring my jb4 and super new to it! I read the definitions and the way im understanding it logging is more about doing pulls than monitoring on a day to day basis in regular driving. My car recently came out of winter storage, chicago, full tank, topped of with stabil, etc. and viewing the jb4 logs it comes across to me that it's running normal when doing the pulls. Drove 200 miles, quarter fuel tank left, topped it off with 93. Drove the car to a wedding and the car sat outside parking lot for about 36 hours. We had some rain and major winds. Not saying my baby got a cold, but i found it interesting when i started it up, my FP_H showed a value of 12, where it typically sits at 5. To my understanding, the fp_h should be between 10-14 during pulls, not when its sitting still. looking at the log, the x-axis at 790 it started to decrease to the regular value of 5, and x-axis was 810. I drove the car home, mainly highway, (sidenote: crazy how long it takes the trans/oil/water temps to raise) after getting of on the highway. Driving in city about 10 minutes, my HP_F value sits at 12 again when i come to a complete stop. I wonder why that is. Is this a sign that the HPFP is going bad? when i release the brake and start moving, the hp_f goes back to regular 5.
I should mention that i noticed my FP_L sat at 75 when its typically in the normal range of 55-70.
Im still learning
JayK JayK is offline
Car: BMW 135IS N54
Default Logging parameters: E85 - 04-20-2018, 05:13 AM
I have a simple question regarding the E85 parameter. How is it measured or what sensor is used to measure E85 mix. Thanks!
adrken2008@gmail.com adrken2008@gmail.com is offline
Car: 08 E90 335i
Default jb4 logging no mph, gear, and others, how to add them - 05-20-2018, 03:23 PM
I just installed jb4 on my stock 08 e90 and love the extra boost it allowed. However, when I logged my data I see "0" values in fields like mph, gear, ign2-6, ... see the attached log for details. My fw is 32/8//2 and the sw version is 9/1/17. Hopefully, one of you guys can set my straight.
thx,
Cinci.e92 Cinci.e92 is offline
Car: 2009 335xi fbo inlets outlets ps1 turbos
Smile 03-27-2019, 10:29 AM
Great write up Russell I think Iím all ready to get in to tuning after this. Read like a book
whytiptoe whytiptoe is offline
Car: 2019 Kia Stinger GT2
Default Understanding Parameters Meanings - 08-07-2019, 12:01 PM
Ok so most of these are listed in this forum, but there are some that are not. If someone could assist me that would be great. I am looking to learn what they are for the KIA as most of this is for the BMW's motors. Thank you in advance for your help.
Timestamp = time since logging started
RPM = RPM of engine
ECU_PSI = ECU/DME observed boost
Pedal = Gas pedal input
IAT = Inlet air temperature
Fuelen = value changes on firmware and engine type
Firmware 10, Lambada II T-GDi. So what does Fuelen mean?
Wgdc = not listed but seams to be always 0
Throttle = throttle blade position (0-100%)
Fp_h = fuel pressure high system
Calc_torque = not listed
What does it mean, I can take a guess
Dme_bt = DME boost set point
Meth = Methanol flow
Fp_l = fuel pressure low system
Gear = Current selected gear.
Stinger seams to always be 0
FF = Feed Forward
Load = DME load index
Clock = not import to anyone other than BMS
Map = map selected
Trims = fuel trims
Trims2 = not listed
AFR = AFR for bank 1
AFR2 = AFR for bank 2
ING_1,2,3,4,5,6 = ignition advance cylinder 1,2,3,4,5,6
Avg_ign = Average ignition retard for E series and some F series models
So what does it mean for the Lambada II T-GDi
Oilf = not listed
Can take a guess, but seams to always be 0
Waterf = not listed
Can take a guess, but not listed
Transf = not listed
E85 = not listed
Target = JB4ís target boost
Boost = PSI in charge pipe
Boost_2 = not listed
MPH = not listed
Don't really need anyone to tell me as it is MPH, just not listed.
Jsg's Avatar
Jsg Jsg is offline
Car: 335ix
Default 09-30-2019, 12:43 PM
At what iat dme normally start to pull back timing I just try to evaluate and understand log?
Ratis_project Ratis_project is offline
Car: Serie 3 e92 n54
Default 02-25-2020, 04:56 PM
hello everyone, could someone help me I have problems and I don't know how to interpret this
Bbelstad's Avatar
Bbelstad Bbelstad is offline
Car: 08 E60 535i
Default 02-25-2020, 09:00 PM
Please repost this in the "support and log review" section. Pro's will help you figure it out if you post along with this log in that section.
Brandon
Hayden, Idaho.
* 08' 535I. * JB4 W/ Bluetooth Connect & custom tune. * Billy Boat 535I 3.5" *****-back exhaust W/ resonator delete. * BMS DCI. * NGK 2 step colder plugs @ .020" (And I mean .020" on money!). * New Eldor coils. * BMS BOV adapter and BMS Vac side OCC. * BMS Chargepipe. * TIAL BOV W/ Hard 1/4" Vacuum line W/stock spring. * XHP Stage 2 * C-@-T TUBES.
[/SIGPIC]
shaftstall shaftstall is offline
Car: 2018 340i
Default Define a good log - 03-10-2020, 06:26 AM
I’ve been reading everything I can, but I’ve yet to come across the definition of a good log. Everyone just refers to a pull, but no context. Is this a 0-60 run? Rolling start? Does it matter if you are in sport mode or not?
Edit: Never mind, I found my own answer. For the other newbies this link has the best explanation I have found for the process: BMW N54 Ultimate Data Logging Guide - JB4 Data Logging
Dagumpf's Avatar
Dagumpf Dagumpf is offline
FS
Car: BMW E93 N54 2009
Default 07-07-2020, 11:57 AM
Originally Posted by RoN
Guys... in new firmware of JB4 (v31) Duty Cycle in logs means the calculated torque.
How can I understand this from my log? For example if my DutyCycle reach 2600 level, how much Nm it means?
I have a similar question, I can't find the answer on the forum. The Sticky says "In newer firmware versions has been changed to reflect calculated engine torque scaled from 0-7000rpm = 0-100lb/ft of torque", but that cannot be right, at best it should be 0-7000 = 0-1000lb/ft.
Please can this be confirmed? In this case, a value of 3100 = 442 lb/ft = 600 Nm. Is this correct?
Car: 2003 Forester
Default 07-07-2020, 12:28 PM
Originally Posted by shaftstall
Iíve been reading everything I can, but Iíve yet to come across the definition of a good log. Everyone just refers to a pull, but no context. Is this a 0-60 run? Rolling start? Does it matter if you are in sport mode or not?
Great link for fellow noobs. Thanks.
JonEQuest JonEQuest is offline
Car: 2008 335i Convertible
Default Confused on multiple logs. - 07-20-2020, 03:56 PM
I did 3 hard pulls the other day and now I have about 15-20 logs with cryptic numbers. Why does it create so many small logs? I thought I would have 3 good long logs, instead I have so many I have no idea how to correlate what run I did with what log I got from it. They also have random file names so I can't even tell the order of log 1, log 2, log 3 etc.
One more question. I see a "combine logs" in my JB4 but not sure how that works. Would it combine them in the order they were made so it is one long log? The JB4 log names, and identification are definitely not user friendly.
Dagumpf's Avatar
FS
Default 07-21-2020, 12:29 AM
You should get one log for each hard run. If you are getting other spurious logs, consider logging manually, or changing the log settings: in the App, go to App Settings, Logging Settings, and check your settings there. Nothing you can do about the naming.
Default 07-21-2020, 07:18 AM
What settings would you recommend? I bought this used over a year ago and some settings were already out of whack.
Dagumpf's Avatar
FS
Default 07-21-2020, 07:21 AM
Make sure you have latest firmware. Then I have mine set to 3s WOT autolog timeout and 90% Autolog Threshold.
Default 07-21-2020, 07:33 AM
