SYTFU Crew
Car: 2007 E92 335i
04-26-2011, 10:56 PM
Hurry up Alphatesters! lol
Car: 335i M sport
04-27-2011, 07:47 AM
So the fail safe wont work on custom map 6 ? Will map 3 also have user adjustable menu for the air/fuel/boost/cps ? Because I wanted to get it dyno tuned. lmk. Thanks.
2014 - M6 f06, FabWorx Ctlss DP's, JB4, FSB meth, Turner Exhaust.
2012 - 650i M sport JB stage 1 (Gone)
2009 - 335i N54 JB4, DINAN CAI, MACHT SHNELL DP'S, HPF FMIC, ER CP, SYNAPSE BOV, EISENMANN RACE EXHAUST, BT OIL CC, COOLINGMIST/SNOW PERFORMANCE METH INJECTION - 427 WHP DYNOJET (Gone)
04-27-2011, 09:15 AM
Is there anyway to make the automatic transmission not shift in sport mode unless you tell it to? Im sure you have driven before and seen it just switch out of DS into D.
Car: '07 SGM 335i
04-27-2011, 09:29 AM
Once you move the shift lever over to DS it should not switch to D. The car will still shift itself in DS, it just stays in each gear longer (among other things). The only way to truly control your own shifts is to upshift or downshift into Manual mode (M).
04-27-2011, 09:35 AM
No, if you are shifting yourself in Manual mode if you wait to long it will shift itself.
Car: '07 SGM 335i
04-27-2011, 09:36 AM
Only if it hits the rev limiter
04-27-2011, 09:40 AM
Nope. This question was directed for Terry anyway.
Car: '07 SGM 335i
04-27-2011, 10:37 AM
Let me slow this down for you, please take notes.
1) The inquiry was not addressed to Terry, it was a general post to the thread. Terry is busy developing features for JB4, I'm sure he appreciates knowledgeable users assisting in the answering of questions.
2) If in full automatic mode (D) and you manually shift, it will eventually go back to full automatic (D). However, if you move the shift lever into sport mode (DS) and you shift manually it will convert to full manual mode (M) and will not shift until you A) shift, b) hit the rev limiter, or C) move the shift lever back to full automatic (D).
04-27-2011, 10:53 AM
Why do you go try this. Switch into sport mode, use the paddle shifters, go into second gear, dont shift, let it hang out around 5000rpm for a while. Tell me what happens.
Car: 2008 335xi
04-27-2011, 10:56 AM
The previous owner of my car did the exhaust flap mod be removing the tube and plugging the ports. I want to put the tube back in and use the JB4 to do this is software. Anyone know where I could get some of that tubing and what size/diameter I need?
Car: 335 coupe
04-27-2011, 03:07 PM
Doing some logs tonight if the rain holds out
Car: BMW 135i
+1. On that particular situation, it will happen. I hate it when that happens on a rolling start race. It will grab the next gear right before I hit the gas. You can lose a car lenght until it shifts back down and starts pushing forward.
Back to JB4 stuff.
2009 135i auto, JB4, DP fix, Code 3 intercooler, RR *********, RR full intake system, custom 3in exhaust with Magnaflow pipe.
04-27-2011, 03:27 PM
Added 4/22 with a couple CANflap bugs fixed.
;o
Car: E92 335i/320i
04-27-2011, 03:28 PM
awesome
Great work Mr T
04-27-2011, 05:01 PM
If I had to answer one more email asking why CANflap isn't saving when they go back in menu 4 I was going to shoot myself in the head. So updated the 4/22 firmware to reflect the saved position when entering the menu. Will post the firmware in a few minutes.
I saw around 7 of you grabbed it before I made this change. Just delete it and redownload.
Car: 335i M sport
04-27-2011, 05:12 PM
BUMP
04-27-2011, 05:25 PM
BUMP
If you are using methanol you'll be using map 3 only. You set the boost curve using the meth additive field. AFR and CPS curves are set as normal. With meth as is with race gas, CPS should be set to all zeros.
04-27-2011, 05:33 PM
Put 4/22 back up with the menu change.
;o
Car: E92 335i/320i
04-27-2011, 05:34 PM
downloaded
Car: '11 335is DCT
04-27-2011, 06:02 PM
Haha! Cool!
04-27-2011, 11:28 PM
So the Interface is all good just the firmware was being fixed for bugs?
It been raining non stop so haven't been able to log but the new interface is awesome.
135i - JB4 15ohm l Mr 5 Intake l AA C@tless ********* l ETS Intercooler l BMS Methanol Injection l Berk Tech Mids l Berk Tech Axleback l BMS OCC l ER CP l Turbosmart BOV's. SOLD
335i DCT - JB4 G5 ISO l AA C@tless ********* l ETS Intercooler l Custom Intake l Meth l BMS E85 Flash l BMS OCC l ER CP l Walbro 255 l Turbosmart BOV's. CURRENT
Engineer
Car: 2008 BSM 335i Coupe
04-28-2011, 05:27 AM
Back to JB4 stuff.
If you brake boost before the rolling start, you'll should have no problems with it upshifting.
2008 BSM 335i coupe-jb4.BMS intake.meth
1999 Pontiac Grand Prix-10.5PSI.PRJ LL Cam.supporting mods
04-28-2011, 10:53 AM
loaded 4/22 with no problems. I don't know if it's it's just me but the car seemed louder when cold with the golf tee mod physically in place. Map 5 feels stronger than previous firmware.
04-28-2011, 10:54 AM
Peek in the tailpipe and make sure the flapper is open.
Country Roads!
Car: 2009 135i
04-28-2011, 11:01 AM
Terry, did you do anything that would change how the car feels down low? Not sure what the deal is, or if I just got a really good tank of fuel, but it feels like she has a whole lot more oomph down low.
Thread Tools |
Display Modes |
