(#951)
DeadEye's Avatar
DeadEye DeadEye is offline
Default 01-23-2011, 11:48 AM
It's just a communication standard the vehicle modules use to communicate with each other. Giving the JB4 the same module allows it to "join the club" and get all the dirt and gossip on the other modules including the DME.
I'm sure my sat-nav has been spreading rumours about the footwell module. Can the JB4 confirm?
Default 01-23-2011, 12:05 PM
lol!
Eleventeen Eleventeen is offline
Car: 2007 335i
Default 01-23-2011, 12:48 PM
Terry, is the JB4 capable of determining how much boost the DME is looking for, and feeding that value back to the DME, independent of actual boost?
Ferrari Red F80
Default 01-23-2011, 12:53 PM
Sure. But it isn't setup to run the wastegates directly full time. So we only plan to use that trick in special cases like during manual transmission WOT shifts where we're watching everything and give the OK to hang the throttle open during the shift.
Car: 2007 335i
Default 01-23-2011, 01:03 PM
My idea was to run a single turbo but one w/ an internal wastegate and the OEM vacuum actuator to avoid a tuning nightmare. However, I was thinking that with a single turbo (or bigger twins) the DME would need to see boost down low, but might throw a CEL if there is too much turbo lag.
Ferrari Red F80
Default 01-23-2011, 01:17 PM
For single turbo you'd need our PRO board, which can run the solenoids (or a new one) completely independently of the OEM setup.
Car: 2007 335i
Default 01-23-2011, 01:20 PM
ETA please!
Ferrari Red F80
Default 01-23-2011, 02:36 PM
Don't have one. Plenty of work to go on it and we're busy on JB4 stuff right now.
JomarPR335R's Avatar
JomarPR335R JomarPR335R is offline
Car: 335i coupe 08'-545i 05'smg- civic 95' 600whp
Default 12. - 01-23-2011, 03:05 PM
I sent to you My numbers and logs of the track day
335I E92 Alpine white
12.56 @ 114.32 2.0 60ft with 335IS 19" wheels A/T
Stockin !!!
JB4 MAP 7 - VP116 - DCI - FMIC - with Hot temp 83'F
hiofficer hiofficer is offline
Default 01-23-2011, 06:48 PM
Good place to post a feature request?
Would be great to be able to autoclear just the ******** codes but not all engine codes. I'm assuming autoclear does the latter.
shoes's Avatar
shoes shoes is offline
Car: 07 BSM E92 335i
Default 01-23-2011, 07:43 PM
T, any info on "autotuning" yet?
ultimateracing 335 ultimateracing 335 is offline
ultimate racing 335
Car: 335i sedan
Default 01-23-2011, 07:53 PM
Hey Terry when instaling the jb4 we remove our o2 ****? Can we still keep it in so we dont have to use auto clear?
Default 01-23-2011, 07:58 PM
Up to you but I'd suggest removing it. Fewer changes for headaches later.
Default 01-23-2011, 08:00 PM
Code deletion is an all or nothing deal. But if you throw a non-*** code you'll get a check engine light and can disable auto clear at that point. You can even read the code through the dash if you want.
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 01-23-2011, 09:59 PM
Gona start playing with some features tommrrow within the JB4 interface.. Very intersted in the first and second gear boost redux features.
So to get the understanding of how this feature works.. I am running Map2 on 93octane. I enter lets say 5 into the 1st gear redux, and it will subtract 5 psi from lets say the targeted boost?
2014 F10 535i N55 PWG
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 01-23-2011, 11:06 PM
The attached file on the first post:
Is that the lastest firmware update? was that preloaded on the beta batch that shipped out on the 16th?
I haven't updated anything yet.
rmdvrs rmdvrs is offline
Car: e92 335i
Default 01-24-2011, 12:22 AM
Yes that is the latest public firmware update. If your not sure just plug your computer into the JB and the interface will tell you what firmware is loaded and interface version you are using.
scott135i scott135i is offline
Car: 135i / 335i / Z4 3.5
Default 01-24-2011, 12:09 PM
Once your PC is connected to the JB4, go to the 'User Adjustment' tab in the JB4 software...
There you will see the current FW version and interface version that you currently have...
Look on the right side under 'Firmware Ver'
http://www.n54tech.com/forums/attach...1&d=1293331046
elsabor67's Avatar
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 01-24-2011, 03:02 PM
I got my JB4 today and installed in the car. Question though, when you are on the settings page I tried to read the DME codes if it had any and got a read failed. Is the car supposed to have ignition on and NOT running or did I just miss something??
Also, when I tried to do it off the gauges, I got 2 flashes and then 4flashes and it came out of command mode by itself. Is this normal?
Thanks for the help in advance
Default 01-24-2011, 03:10 PM
Code reading via laptop only works with 1/1 and later firmware. 2 dashes with 4 dashes means no codes stored.
Bizall's Avatar
Bizall Bizall is offline
Car: 2008 BMW 135i
Default 01-24-2011, 04:02 PM
You need to type 50, not 5 for a 5psi reduction. Scaling is 0-100...just remember, it will not go lower than stock boost no matter how high you put the gear redux. Enjoy!
2014 BMW 335i Sedan 8 Speed Auto
JB4 Map 7/Intake/E40
12.49 @113 mph with Continental DWS All-season tires
Default 01-24-2011, 04:13 PM
+1. Also, in the next update that changes to a boost cap per gear. And you enter say 10.0 for maximum 10psi in 1st gear, etc.
elsabor67's Avatar
Enjoys Retirement
Default 01-24-2011, 09:21 PM
Thanks Terry.
MusclezMarinara's Avatar
MusclezMarinara MusclezMarinara is offline
Ma need more protein !
Car: 2009 335i x drive
Default 01-24-2011, 09:34 PM
Map 6 is for doing custom mapping. If you don't know how to do custom mapping (including reading any codes you generate) I strongly suggest not touching map 6.
Terry
i didnt have my laptop with me it happened on the highway, so no laptop.
Also its set to the parameters on the screenshot on the first posting.
2009 335 xdrive - Muff Delete, JB4 (ALPHA), DCIs, V701 GM, CF Splitters, +mas
