(#926)
SlicktopTTZ's Avatar
Turbo Lover
Car: 300zx TT, 1M
Default 01-21-2011, 06:46 PM
Hmm, project black box......
Jayock's Avatar
Jayock Jayock is offline
Enginerd
Car: 2009 135i
Default 01-21-2011, 06:52 PM
Haha.... Perhaps the name oversells the merits of the actual project.
hind327 hind327 is offline
Default 01-21-2011, 09:34 PM
Terry, whats the status of availability to enable "Max Cool" feature?
///135i LeMans - Riss Racing OCC, Shadowline Grills, Magnaflow Axle-Back, JB4, ETS FMIC, BMW DCI, BMW Perf Side Skirts, E93 M3 Front Sway
Flickr
Default 01-21-2011, 09:44 PM
I've been slacking a bit with that working on other features. It hasn't moved beyond the "we found the right can commands" phase yet.
2Slow's Avatar
2Slow 2Slow is offline
Velocity Challenged
Car: 2007 335i AT
Default 01-21-2011, 10:01 PM
You're such a slacker T...
Dirty Dog's Avatar
Default 01-21-2011, 10:30 PM
Terry I think it's time to clone yourself to produce half a dozen Terry's with your work load.
Maybe you can add that to the CAN system.
Default 01-21-2011, 10:52 PM
I have the number to Re-pet somewhere around here.....
Flickr
Kevron Kevron is offline
Car: 2007 335i
Default 01-22-2011, 02:48 PM
Hey Terry, not sure if it's been brought up or not already since there's about a million pages on this post already but how about getting some rev matched down shifts out of the JB4? I'm assuming that since we can have gear dependant boost then the JB4 must have access to what gear the tranny is in and then match the engine accordingly...
Default 01-22-2011, 02:53 PM
It is possible but not on the radar right now. Would require a lot of safety testing.
Turbo Lover
Car: 300zx TT, 1M
Default 01-22-2011, 03:07 PM
379Z style
370Z style! That would be awesome.
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 01-22-2011, 03:26 PM
Does it only assume first and second gear by the wheel speed?
Default 01-22-2011, 03:41 PM
It comes from the DME itself.
Car: 2007 335i
Default 01-22-2011, 03:46 PM
Ok cool, just wanted to plant the seed you know... Lolz, yea I was thinking 370Z style, kinda novelty bit still cool and I would use it... I know it'd prolly take time to perfect but in simple terms it seems easy enough, DME gear sensor and a predetermined engine speed based on DME speed info, prolly be an extensive amount of calculations that my simple mind can't fathom......
Car: 335 coupe
Default 01-22-2011, 07:09 PM
Do you think there's some sort of strain gauge in the shifter or is the DME assuming it by wheel speed?
Default 01-22-2011, 07:11 PM
It's pretty spot on with manuals, even goes to 0 during the shift. Must be a sensor.
Car: 335 coupe
Default 01-22-2011, 07:12 PM
Neato.
Car: 2007 335i
Default 01-22-2011, 09:02 PM
Yea that's what I guessed, lol, took my car for a spin a few mins ago for the first time since installing the JBfour and saw the gear field change while monitoring my run, oh yeah thanks for the awesome product Terry, I noticed a HUGE increase in butt dyno horsey powers, lol.
moodi's Avatar
moodi moodi is offline
Car: 335I
Default 01-22-2011, 10:07 PM
guys may i throw an amateur Q :whats CAN? what is it used for?
roninsoldier83 roninsoldier83 is offline
Car: E90 335xi 6MT
Default 01-23-2011, 12:21 AM
Terry,
I have a fully stock 335xi (other than JB4 of course!) at 5200 ft elevation. If I planning on running around a 50/50 mix of 91 octane & 100 octane (around ~95-96-ish octane) for either a couple of drag strip passes or dyno pulls, which map would you recommend? Should I stay on Map 1 (car is still stock), or should I bump it up to Map 2 due to the higher knock threshold using higher octane fuel (around 95-96 octane or so)? Thanks in advance!
P.S. The partial throttle boost onset really is MUCH smoother than it ever was on the JB3... I was truly shocked that it was actually so readily noticeable. Very nice
iv55 iv55 is offline
Car: 2007 335i coupe
Default 01-23-2011, 08:40 AM
Controller–area network (CAN or CAN-bus) is a vehicle bus standard designed to allow microcontrollers and devices to communicate with each other within a vehicle without a host computer.
CAN is a message based protocol, designed specifically for automotive applications but now also used in other areas such as industrial automation and medical equipment.
Wikipedia makes everyone smarter
It's pretty much your car's computer system. It controls your displays. It takes input from the driver via buttons, switches, etc. It does all kinds of stuff but I'm sure Terry could give you a much more elegant answer.
2007 E92 N54, JB4 G5 ISO W/ BMS Flash, RB Turbos, Meth W/ FSB & CM10, BMS DCI, BMS OCC, CPE FMIC, AR Design CLDP's, DP Fix, Quaife LSD
MusclezMarinara's Avatar
MusclezMarinara MusclezMarinara is offline
Ma need more protein !
Car: 2009 335i x drive
Default 01-23-2011, 09:55 AM
Just curious if anyone has come across this issue.
Ran map 6 on 93 octane for about a mile...got a SES light..im assuming this is because its not running race fuel....activated the code clearing and went back to map 2 alls well. Just curious
2009 335 xdrive - Muff Delete, JB4 (ALPHA), DCIs, V701 GM, CF Splitters, +mas
e90tiag335i e90tiag335i is offline
Car: 2010 335i
Default 01-23-2011, 11:02 AM
I've ran map 6 and logged a couple runs and I didn't get any codes.
What did you have the boost settings at?
Default 01-23-2011, 11:28 AM
Map 6 is for doing custom mapping. If you don't know how to do custom mapping (including reading any codes you generate) I strongly suggest not touching map 6.
Default 01-23-2011, 11:29 AM
It's just a communication standard the vehicle modules use to communicate with each other. Giving the JB4 the same module allows it to "join the club" and get all the dirt and gossip on the other modules including the DME.
Babyjoe1973 Babyjoe1973 is offline
Car: 135i and M3 E30 Evo III
Send a message via Skype™ to Babyjoe1973
Default 01-23-2011, 11:30 AM
One thing is top urgent for the MAP 6 users! Look at your timing!!!!
Babyjoe
BMW M3 F80 ZCP
