Car: E90 335xi 6MT
01-20-2011, 02:45 PM
Originally Posted by n54-5&3
Hey hey hey there! Don't forget about us N54 535 owners! We don't have no stinkin temp gauge! When I PLAN on beating on the car, I drive with the laptop to watch the temp (partly b/c I wasn't sure whether the failsafe was implemented on all maps yet). Even with the failsafe implemented, that means that the only way I can know if the temp is adequate is to floor it and see if she holds back on me.
Actually sir, I was not aware that the 535's did not have a temp gauge... I can actually see how an indicator feature would be very useful for you 5-series guys, whereas for those such as myself, it would be more of less just an annoyance, or something to freak me out while driving on my way to work
Maybe two loads of firmware? Or a user adjustable feature that is defaulted to off, but can be toggled on?
Turbo Lover
Car: 300zx TT, 1M
01-20-2011, 02:49 PM
Originally Posted by ezatnova
Terry, if this is the case, does that conflict with the page 1 info?
"Map 2: 14.5psi (suggested for 93 octane)"
Also, I believe JB3 Map 3/5 is suggested for basically stock 93 octane, and that's in the same 14-15 psi range...so I would think Map 2 is the "equivalent" in the JB4?
Gas quality varies from place to place, as well as ambient conditions. Some people will get away with Map2 on 93, some won't.
I can run Map2 on the 93 here, but my ignition takes some drops in the higher gears as things start to heat up.
The best and really only way to know if it is ok, is to log your ignition timing.
Oh yes I did.
01-20-2011, 02:52 PM
+1 An option for an indicator such as flashing the hazards once would be nice. It's not as though anyone is going to be seeing the shift-point hazard flash before the car is warm. Even if the option was only available to turn on and off via the computer that would be nice.
Oh yes I did.
01-20-2011, 02:55 PM
Are you below 10 in your higher gears? What do you consider safe?
01-20-2011, 03:09 PM
good news for me..
Turbo Lover
Car: 300zx TT, 1M
01-20-2011, 03:19 PM
Log your ignition through a long gear, like 4th or 5th. Be sure to be full throttle. Your ignition advance should be around 8-10 the whole run, maybe higher, maybe a bit lower. The thing to look for is drop-outs, it will look like a negative spike.
Here is an example, a Map2 log on my car. (DCI/JB4 only on 93)
01-20-2011, 04:22 PM
Stock timing will be around 8-12 degrees, but tuned timing must be much lower. Sometimes even negative. And some areas have essentially preprogrammed drop outs such as around 4200rpm. What you want to look for is repetitive drop outs under high boost and high RPM which indicate you are close to the octane limit.
01-20-2011, 04:24 PM
I'll fix the first page.
Turbo Lover
Car: 300zx TT, 1M
01-20-2011, 04:27 PM
Would you consider that log I posted as repetitive drop-outs? I've been running Map1 to be safe, and it doesn't do that to my ignition.
I have not been able to secure any damn Xylene or MS109 yet.
01-20-2011, 04:31 PM
The first dropout is mapped there but the second two post shift put you close to the edge. It would depend how often they came up, etc. Timing recovers well so you're about at the limit there. The limit means as you push boost higher you stop making additional power.
Turbo Lover
Car: 300zx TT, 1M
01-20-2011, 04:33 PM
So they put in a timing drop at the cam profile change to keep the torque output constant?
01-20-2011, 04:50 PM
No, they cranked the sensitivity of the knock feedback way up there to catch anything happening during the transition. So you get a lot of false knock there.
Car: E90 335xi 6MT
01-20-2011, 05:00 PM
Ahhh that makes sense... so the transition between cam profiles causes somewhat of a false knock, which in turn causes the ECU/DME to pull timing drastically.... make sense why most all of the logs I've seen show timing dropping drastically around that RPM haha. I've been curious about that for a while, and am rather new to these cars (former Subaru guy that tuned mostly with OpenECU & logged with RomRaider), so I never realized that. Kind of shocked BMW didn't work on "fixing" that per se.
Since the new N55 has Valvetronic, which as I understand it constantly varies lift/duration (kind of like Nissan/Infiniti's VQ37 motor in the 370Z/G37), is this dip in timing absent on those motors?
01-20-2011, 05:05 PM
The N55 is a whole new animal with a different ECU and knock detection system. But seems to be a lot smoother there, at least at the +3psi tuned range.
Car: 335i e92
01-20-2011, 07:25 PM
We could include one if you guys want. Have it flash the blinkers when the oil temp is > 160? Or maybe have it roll open the windows and moon roof, and crank the radio up to max?
have it roll down the windows and crank "Kenny Loggins - Danger Zone"
Enginerd
Car: 2009 135i
01-20-2011, 07:31 PM
YES!!! Also put in a "buzz the tower mode"
Oh yes I did.
01-20-2011, 08:52 PM
So how does this look? (starting in second gear and rolling on throttle due to wheelspin). Is advance getting too low in 4th?
01-20-2011, 08:56 PM
The JB4 interface logs for you and is much easier to read. Why the excel log?
But looks good! There is no such thing as "too low advance". During certain times it will run 0 or less and that is perfectly fine. Advance also has to drop as your rate of acceleration drops under wide open throttle. So each gear will target a lower advance than the previous generally. What you want to watch out for is sustained sharp drops that repeat with no other explanation.
Car: '07 e92 335i
01-20-2011, 08:59 PM
Just got my JB4 in the mail can't wait to install! Quick question thought...what is Map 5 for the JB4 i don't see anything listed for it on the first post.
Oh yes I did.
01-20-2011, 09:08 PM
Easier to read to 99%... your forgetting the 1%. I'm a bit off.
I wanted different scaling and a bigger chart. I save different pictures of different charts showing the data I want, making it easier for me to compare them later.
I'm glad it's looking good, thanks.
01-20-2011, 09:12 PM
No problem. I thought maybe you didn't know it could be done within the interface.
Car: bmw 135i
01-21-2011, 09:24 AM
if I'm wrong map JB4 2 of 7 corresponds to the JB3 map with more power but ...
01-21-2011, 09:33 AM
am I dumb or what? I turn of my radio by pushing the volume button in. As soon as I enter command mode it turns back on. If I turn it off by pushing the volume button again, a touch of the volume up or down or channel select and it comes back on.
Car: '07 SGM 335i
01-21-2011, 09:37 AM
I take it you have iDrive? Mine does the same thing, volume goes up and down and stations change as I navigate through the menu. Adds character to the experience.
01-21-2011, 09:39 AM
yep. kind of sucks because it changes the song and sh!t.
Thread Tools |
Display Modes |
