boostedloony boostedloony is offline
Car: 07 335i
Default need help - 07-18-2020, 03:56 PM
ok so my afr is still lean and my fuel trim is maxed positive I finally am getting decent boost after finding a vacuum leak and cleaning me dvs but like I said I still have these problems here is a log and picture tell me what I should be looking for possibly fuel pressure not sure when I first start it cold it kinda hiccups and then will smooth out but only when cold someone said something about a vac line that needs plugged because I have a full exhaust and the flapper is gone but I haven't looked for that yet possibly need fuel trims adjusted not sure im running a j4b with pump bef on 93 octane I have td04 17t turbos vsrf inlets and intercooler with chargepipe and forge dvs dual cones 3 inch ******* *** 4 inch single exit exhaust 2 step colder plugs delco coils I just want to fix my car please help
Car: 2008 E93
Default 07-18-2020, 06:07 PM
Hybrid BEF and default settings for hybrids.
Log map 1 and post up
Car: 07 335i
Default 07-18-2020, 06:45 PM
The only maps in he burgermotorsports file for hybrid are e85 maps and I dont have an upgraded fuel pump yet
Car: 2008 E93
Default 07-18-2020, 07:07 PM
Then default settings for hybrids and log map 1
Car: 07 335i
Default 07-18-2020, 07:46 PM
Are you talking about using map 6 on jb4 and default setting for a hybrid or are you saying theres a way to set a default bef? Can you explain more possibly a link? How would I do default hybrid settings on map 6 and then log map 1 wouldnt that just revert to the the mhd map 1 settings
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 07-18-2020, 08:52 PM
He means on your pump flash set the JB4 to the hybrid default setting while you on same flash but using the hybrid jb4 setting and run map 1 and post a log
Car: 07 335i
Default 07-18-2020, 10:05 PM
I have a screenshot of jb4 settings but I'm not seeing a hybrid default? Is it something with the newest firmware? Also I fixed a vacuum line and the afr got really lean I dont get it
Car: 2008 E93
Default 07-18-2020, 11:17 PM
JB4 N54 Hybrid Turbo Setup Directions - N54Tech.com - International Turbo Racing Discussion
Car: 07 335i
Default 07-18-2020, 11:30 PM
So I adjust these settings on map 6 but they are carried over through all the maps?
Car: 07 335i
Default 07-20-2020, 05:22 PM
Ok so I ordered the 4 bar tmap and connector looking at those defaults will a stock block 07 335i handle 25psi?
Default 07-21-2020, 05:58 AM
Some do, some donít. Depends on motor / car health
Car: 07 335i
Default 07-21-2020, 10:50 AM
Is there default setting for say a 20psi map
Car: 07 335i
Default 07-21-2020, 10:51 AM
And if I adjust these default setting with the 25psi like recommended does running map 1 or 2 decrease the psi I will be targeting
