Hello guys. I am trying to deal with some problems on my recently bought E93 N54 2007
When the car is cold (not started for more than 5 to 6 hours) I am having a rough start with check engine light and of course limp mode. By rough start I mean normal crank start, but very bad engine work with loud injectors and RPM between 500 and 1500. After some seconds (maybe 30 I presume) the engine is starting to work normally (650~ RPM) with limp mode. Then if I shut off and start again the engine – everything is working smoothly. I repeat, this only happens on cold start.
Another problem (I think its not related to the first, but I am not sure) is cylinder injection cut when I kickdown. Restarting the engine is fixing the problem.
The error codes I am getting are:
Code:
0029DC – cylinder injection cut – the second problem
0029F2 – high-pressure fuel system, fuel pressure – after the rough cold start
I am not sure where could be the problem – the HPFP or some injector failing?
The things I’ve done so far by know:
Code:
- 002E8E – intelligent battery sensor, communication
- 002E98 – generator, communication
- 002E85 – electric coolant pump, communication
- 002E83 – electric coolant pump, energy operation
All of the above problems was fixed by changing the voltage regulator for generator.
Code:
- 0029F3 – fuel sensor, electric
- 0029F1 – fuel pressure plausibility
- 02AAF – Fuel pump, plausibility
All of the above problems was fixed by changing the low-pressure sensor with the new design of Bosh.
Code:
- 0029D0 – Misfiring, cylinder 4
The problem was fixed with changing the injector for cylinder 4 (with brand new index 12).
All of the spark plugs are also changed.
Intake valves are recently cleaned.
Thank you in advance and sorry for my bad english!
