Noah_wiso's Avatar
Noah_wiso Noah_wiso is offline
Car: 07 bmw 335i
Exclamation Can someone help me trouble shoot - 05-27-2020, 03:51 PM
I recently just changed to the hybrid e85 mhd bef. Im going for a e50 mix It ran great the first day. Now I'm getting kicked into map 4 with the hazards flashing twice running lean. I have no clue what I'm looking at in the data logs can someone plz help me
N54 mod list vargas gc 2.0 lite, vtt inlets and outlets, stage 2 intercooler, hks bov, jb4 mhd bef hybrid e85, e50, stage 2 fuel-it ngk 97506 spark plugs gapped to .019, oil catch can
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 05-27-2020, 05:30 PM
Upload the log as is without converting it to pdf as it mix all the format,
Just from a quick log you are overboost amd your boost safely set to 21 so it kick you to map 4, raise you boost safe limit,
Upload proper format log csv file so others can read it
Ifreezebmx562 Ifreezebmx562 is offline
Car: N54 335i
Default 05-27-2020, 10:29 PM
Post the JB4 log, send it to your email then Upload it here.
Default 05-28-2020, 08:44 AM
Set your FUD setting to match our hybrid sticky
Lower your FF to 70 relog map 1 or 2
Noah_wiso's Avatar
Car: 07 bmw 335i
Default 05-29-2020, 08:40 AM
Can you plz explain more what it is and where I can change them. I'm a dumbass when it comes to messing with jb4 settings
Default 05-29-2020, 10:22 AM
Familiarize yourself with this thread, contains anything you need, itíll help you long term to get familiar with all of this:
JB4 N54 Hybrid Turbo Setup Directions - N54Tech.com - International Turbo Racing Discussion
Noah_wiso's Avatar
Car: 07 bmw 335i
Default Changed the settings - 06-01-2020, 10:48 AM
Ok I changed the fud setting to match hybrid sticky
And lowered my gf to 70. I took a log on map 2
Default 06-01-2020, 06:38 PM
You’ll want to enable 6cyl timing
What ethanol mix are you using?
Noah_wiso's Avatar
Car: 07 bmw 335i
Default 06-02-2020, 05:10 AM
Shooting for a e50
