Jmgonzalez6212 Jmgonzalez6212 is offline
Car: 335i 6 M/T
Default 2E33!!! - 05-08-2020, 07:52 PM
Does anyone know what could cause a 2E33? I just replaced my previous injectors to index 12. Coils are new less then a month and I went with eldors, and I put new plug in. I started it up and same issue injection valve cylinder 4, input signal. Any help will be appreciated
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 05-09-2020, 03:17 AM
I assume you coded the new injectors.
Could be the wiring harness,power or grounds. I would check those with voltmeter before going to the DME to check mosfet if its MSD80
Car: 335i 6 M/T
Default 05-09-2020, 09:30 AM
Yes I coded them with the protool app. I check the wiring harness and everything checks good. I replaced the mosfets almost a year ago. So don’t know if another blew out which would be odd. Could it be the psu’s gave out?
Car: 335i 6 M/T
Default 05-15-2020, 02:44 PM
Ended up being DME. I switched to msd81 and car runs strong now
