Originally Posted by Bmw335turbo
Based on your year model that it is normal to have wastegate
rattle.
Late 2008 , the rattle from exhaust only when I press the brake paddle 5 to 6 times quickly on park and still stand. Otherwise its not rattling on cold start or anything that's why I assume as brake booster take vacuum from the engine vacuum lines on the same line that goes to the exhaust flap, just wanted to check if its normal behavior or i may have vacuum leak on that specific end towards flapper
