Barnette335i Barnette335i is offline
Car: 2007 335i e92
Default No boost on any map after jb4 install - 01-18-2020, 06:42 AM
I recently installed a new(from bms) jb4. I had no boost leak codes or boost issues prior to jb4 install. I took the car out for a test drive after installing the jb4. I let the car warm up, switched to map 5 and punched it. No boost and 30FF code. Tried map 1 same effect. Tried map 0. No boost code , but still no boost. I updated the firmware still no boost. I added my logs. Am I missing something? Thanks.
Car: 2007 335i e92
Default No boost after install. Check my logs! PLEASE HELP!! - 01-18-2020, 05:25 PM
Just installed a new JB4 from BMS. I have no boost. Took out the JB4..boost came back immediately.
2007 e92
Default 01-18-2020, 11:02 PM
What is your tach set to? Double check that it is 4/3 (doesn’t appear you are running a BEF).
I’d also double check all wiring / make sure a harness isn’t flipped.
Combined your threads- no reason for 2.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 01-19-2020, 04:49 AM
2007 e92
did you follow the user settings? check the jb4 installation and user setting and make sure its set correctly.
