(#3726)
Phataxe's Avatar
Phataxe Phataxe is offline
Car: 2014 435I
Default 02-02-2020, 12:30 PM
Set Duty Bias to 50 across the board...
'14 435I RWD MHD "Shoup Custom Tune" ° BigBoost Stage 3 Turbo ° Spool FX-150 ° XHP Trans Tune ° VRSF Race Cooler ° VRSF CP ° BMS Intake ° Borla ATAK Exhaust ° Custom Down-pipe ° Stage 3 LPFP ° BMP4 EKP ° M Performance LSD ° Phoenix Racing PI Intake Manifold ° AIC2-P controller ° e85 ° 3.5 TMAP ° NGK 5992 Plugs "0.020"
Default 02-02-2020, 02:14 PM
Originally Posted by Dumaurier7
Hello all, I have the newest version of the JB4 installed in my F22, seems to be working fine thus far! I went ahead an pulled the trigger on a Bluetooth connect kit and installed it which was very simple as well as this again is the newest version so there is no need to tap into the JB4s' power wire,just plug in, secure and go! Problem is the device does not connect ! am I missing something? are there special in app settings?
Maybe you have an older board that does not support the internal power wire? Photo of the JB4 control board?
Ky1e Ky1e is offline
Car: 2014 BMW 435i
Default 02-02-2020, 09:51 PM
Even on map 5?
Phataxe's Avatar
Car: 2014 435I
Default 02-02-2020, 09:53 PM
Read thru the posts you do it on all EWG jb4's
Car: 2014 BMW 435i
Default 02-02-2020, 09:56 PM
Sweet, thanks for the heads up!
Dumaurier7 Dumaurier7 is offline
Car: M235i
Default 02-03-2020, 01:36 PM
Fixed it.
Car: M235i
Default 02-03-2020, 01:38 PM
Originally Posted by JLBimmer
Is there an update on this with firmware. I have used the method described in video to avoid the fault code at start and still happens. I have a 2016 435 xi F36 N55. I have the JB4 BEF and running JB4 Map5 with EWG.
running the EWG_16 firmware
Same with me!
tauzins tauzins is offline
Car: 2014 335i m-sport
Default 02-05-2020, 08:26 PM
Originally Posted by Gerard
@Terry
Is there any way to go back on updates?
Both EWG_17 don't seem to allow dash hijack.
Settings don't save, the needles make no sense. It doesnt even let you go to setting 8.
On the T10 revision the needle will stay put...but about every 8ish seconds it flickers to zero then goes right back to its original placement.
EWG16_Test doesn't save the dash hijack setting either.
EWG_16 worked just fine on the N55 M2
i have the same issue on my 335i
Car: M235i
Default 02-06-2020, 06:16 AM
Same with me!
please hurry up guys, these false codes are really becoming irritating , they still come although I do the power on first work around.
M2_Beasty M2_Beasty is offline
Car: 2017 m2
Default 02-20-2020, 10:16 AM
Anyone know why were told to set FutureUseD bit6 to “on” instead of just running map 2 on its own...? Also if I have no boost safety value in my user adjustment settings should I self input one? Appreciate any and all help!!!
Default 02-20-2020, 11:27 AM
For M2 it's required to set FUD 6 because of the higher DME boost request.
Car: 2017 m2
Default 02-20-2020, 12:34 PM
I see, just tryna make sure I’m not ganna blow my stock charge pipe 😂 ... should I set a boost safety value?
Default 02-20-2020, 01:37 PM
JB4 should already come preset with a boost safety value.
It happens on stock boost levels, you'll eventually want this:
https://www.burgertuning.com/product...0eb619c8&_ss=r
Car: 2017 m2
Default 02-20-2020, 01:42 PM
Appreciate all your help I’m deff going to do my fmic and charge pipe next!! but my values are all 0... can I email you a screenshot or is it safe to send thru here?
Default 02-20-2020, 01:51 PM
Are you connected to the car when checking the values on the JB4 app?
Default values can be found here:
N54Tech.com - International Turbo Racing Discussion - View Single Post - F Chassis N55 JB4
Car: 2017 m2
Default 02-20-2020, 01:58 PM
Yes car is on and I’m connected.... I’m on map 2 with the bef option turned on... should I manually input those values in the link you sent?
Car: M235i
Default 03-05-2020, 02:34 PM
Does the M235 and the M2 run the same block? What’s a safe maximum boost for the 235?
Car: M235i
Default 03-05-2020, 04:09 PM
.......next question! My M235 has an AFE intake, Dinan dual core intercooler, full sprint exhaust, down pipe, JB4 + PI controller, 750cc PI injectors, Phoenix Racing intake manifold and a PR stage 2LPFP, can I run map 3 on 93 pump on this set up ????? I would like to maximize performance whilst I’m working on my turbo upgrade!
My next steps are going to be MHD BEF + EFR 8474 ( custom kit)+ PR coil and fuel line upgrade kits.
Default 03-05-2020, 04:35 PM
You should be okay to run map 3 on 93 only, got any logs?
Car: M235i
Default 03-05-2020, 04:55 PM
👎 I’ll try to get one posted by Saturday, I’m actually installing the LPFP tomorrow
as I’ll. be picking up the lock ring tool tomorrow.
Car: M235i
Default 03-08-2020, 07:17 AM
Hello, did some logging yesterday! How do I post them? Or should I e mail them to you?
Default 03-09-2020, 10:43 AM
Click go advanced and you'll see a paperclip icon. You can upload the CSV files here.
Car: M235i
Default 03-10-2020, 06:32 AM
They arent uploading, I keep getting an error.
Default 03-10-2020, 02:32 PM
What is it saying?
Car: M235i
Default 03-11-2020, 10:00 AM
Think I got it to work! Please see a couple logs from last weekend, I am presently running the stock turbo, meow-less down pipe and full upgraded exhaust (Super Sprint), Dinan dual core intercooler, AFE intake, Phoenix Racing manifold with PI (750cc injectors) controlled by JB4 (map3) and BMS controller, stage 2 LPFP, stock coils and plugs on 93 pump.
