Default The N54 9 second barrier has been broken! - 05-26-2018, 05:50 PM
Congrats to Daniel Buchner of Simply Tuning in Australia who finally broke in to the 9s with his JB4 powered wicked fast single turbo N54! I know he's been at it awhile and finally hit paydirt.
The car is a 2006 e90 335i originally ZF 6 speed with 238,000km on the clock
Full list of mods:
Garrett GTX4202, Turbosmart 45mm wastegate
Custom highmount RHD manifold and 3.5" full turbo back exhaust. 3 mufflers
Bimmer life Audi R8 coil kit
JB4 with custom MHD back end flash E85 34psi
BKC FF intake manifold with 1000cc PI injectors
Turbosmart race port bov and turbosmart FPR 1200 fuel regulator
BMS PI controller
Custom "stage 4" bucketless intake setup with separate feed and return for PI
VRSF 7.5" race intercooler
Stock engine with PPM replacement pistons and rods
Custom Glide adaptor plate and custom converter 5500rpm stall
2 speed power glide, Reid cased, 1.80 billet gearset.
Powerglide yoke welded onto original tailshaft
Stock rear end, welded large case 3.46 diff
328i rear brake calipers with E39 rotors. suit 15x8 5.5bs wheel
275/50R15 Mickey Thompson ET street radial
Stock E60 M5 front wheel
Stock suspension front and rear (238,000km old)
Full interior, leather, electrics, all working, i drive, stock seats, full weight.
Street registered and daily driven.
Car dyno'd at 690rwhp through the glide (Australian HP, I'd estimate around 850 on a dynojet)
All tuning and work done by Daniel Buchner at Simply Tuning!
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 05-26-2018, 07:14 PM
Congrats!
Very impressive, 34 PSI on a 'stock' motor.
No matter how fast I go there's always someone slower in front of me.
You can lead a horse to water but you can't make him Jet Ski.
'10 E92 335 M Sport, JB-4 G5 ISO, 3" CPE Charge pipe, WMI w/dual CM 5 nozzles, 3.5 Tmap, ARM Relocated Inlets (don't do it), VSRF Outlet, BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC. Escort Max 360
Totaled by a careless driver:
'08 E92 335, M sport option
135idct 135idct is offline
Default 05-26-2018, 07:45 PM
any vid?
N54-SHI N54-SHI is offline
Default 05-26-2018, 10:43 PM
Great~~~good sleeper.my love
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 05-27-2018, 02:42 PM
Originally Posted by 135idct
any vid?
https://www.facebook.com/groups/3976...9979692501922/
murdo81 murdo81 is offline
Car: bmw 335i e92
Default 05-27-2018, 07:45 PM
Originally Posted by Rushan
Wrong car in this video. Its not even filmed in Australia.. Should check the facts before loading something up random. The car in the video is burgundy whereas Dan's car is midnight Black...
Aussie e92 335i. Pure Stage 2 Twin Turbos, Pure Performance Motorsports Forge Rods and Pistons, Fuel-it Port Injection, 7.5" Race intercooler, Fuel-it Stage 3 LPFP, Ugraded Fuel lines , Tial 50mm BOV, TFT RHD Inlets, JB4 g5, MHD 98Ron Wedge Hybrid Custom Backend flash, BMS OCC, T20MAP, AR Design 3" Cattless **, Remus Dual 2.5" system with 84mm quad tips, RB PCV valve, AFE intake scoops, Bimmer Coils, CSF Radiator
Car: 2008 E93
Default 05-27-2018, 08:56 PM
Video and log please.
Congrats to the owner !
tmal's Avatar
tmal tmal is offline
Car: BMW E92 335i
Default 05-29-2018, 06:46 AM
https://www.facebook.com/dragracingt...c_location=ufi
2008 E92 335i AT - MMP1k's, MMP inlets/outlets, FMIC WAGNER EVO3, TMAP 3.5 Bar - PRW Stage 2+ LPFP - JB4 g5 - MHD BEF
101Duck's Avatar
101Duck 101Duck is offline
Australia
Car: 2008 135i MT
Default 05-29-2018, 07:38 AM
https://youtu.be/4L4TmKp1CG4
2007 E90 335i M sport
Single turbo, E85, PI
Worlds Quickest N54 and e9x. 10.1 @134mph
Car: 2008 E93
Default 05-29-2018, 09:35 AM
BadAss video. As I said, congrats to the owner. I do have to admit this to ME is not a true BMW 335I breaking into the 9s. Impressive none the less.
Default 05-29-2018, 10:06 AM
finally 9 sec after 10 yrs
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-29-2018, 10:27 AM
So what was the limiting factor that they finally got over? Transmission? Traction?
Can't believe that was with a stock rear end. Not even an LSD?
Car: 2008 E93
Default 05-29-2018, 12:24 PM
Welded spider gears perhaps ?
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 05-29-2018, 12:35 PM
Boost and transmission by the look of it
UK FBO 335i, ̶V̶T̶T̶ ̶G̶C̶s̶ China 19T, JB4, PI meth, BMS CP, OCC, Braided brake lines. Diff Lockdown. TMAP sensor, custom bucketless stage2
N54QC N54QC is offline
Car: 07 BMW 335i
Default 05-29-2018, 06:10 PM
I don't believe over the last few years that power has been a limiting factor. It's mostly been about the drivetrain and getting the power down. Would really be nice seeing someone run 9's with a DD trans, not a powerglide.
weebles weebles is offline
Default 05-29-2018, 06:38 PM
here's the limiting factors up until now.
6at - works okay, doesn't launch perfect but main problem is typically failing once you're north of 600whp.
6mt - boggy shifts and really not a good transmission for banging gears fast.
this car 100% accomplished this because of the transmission swap.
Default 05-29-2018, 09:25 PM
great results
101Duck's Avatar
Australia
Car: 2008 135i MT
Default 05-30-2018, 03:52 AM
I DD my car, so technically this is a DD trans. the only thing I change is the rear wheels. back to 19's with 265 semi slicks for DD duties. This is a true 9 second daily driven street car.
But, don't worry, there's only 10,000 people out there trying, and they're only .7 of a second off! It'll happen eventually.
chadillac2000's Avatar
Car: 2008 535i
Default 05-30-2018, 07:15 AM
101Duck reminding everybody SCOREBOARD.
Although I am legitimately interested to see how a Powerglide operates around town and on the highway. Any videos of that?
Car: 07 BMW 335i
Default 05-30-2018, 11:03 PM
It's a big accomplishment, no doubt. It's great to see a 9 sec N54. We've all been waiting to see it for a long time now. I'm just surprise that you DD it. As chadillac2000 stated, in for more info on DD use. And as you stated, .7 off so pretty unlikely to get to 9's with our trans at this point. Thinking the happy medium is something like a 4L80E unless you can convince people a powerglide is the way to go for DD. Don't know enough about them to say either way other than they have always been primarily used for race applications.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 05-31-2018, 07:56 AM
Amazing times.
I'm not surprised a Power Glide could be DD. It's been done forever, people drove around daily with factory 2- or 3-speed trans all the time back in the early days of motoring. With that said, I'm also in for a video of a DD N54 Power Glide operating around town :D - curious to see.
Agree a 4L80E would be more user-friendly and preferable, of course.
Nitrousbird Nitrousbird is offline
Car: '07 335i 6MT
Default 05-31-2018, 08:00 PM
4L80E is big and hard to fit.
I don't understand why a built 4L60E or even a TH350 or TH400 wasn't used instead.
Magnusk77's Avatar
Magnusk77 Magnusk77 is offline
Car: BMW 135i
Default 06-22-2019, 09:36 AM
Wait stock rear end aside from welded diff? Like stock axles and driveshaft?
2009 BMW 135i - Monaco Blue
Prototype007 Prototype007 is offline
Car: 2009 335i
Default 06-23-2019, 07:17 PM
First gear in a glide doesn’t hit that hard.
All I’ve managed to break in mine thus far was busting teeth off the ring gear.
2009 335i Automatic Coupe.
landshark92 landshark92 is offline
Car: 2013 335is
Default 06-23-2019, 08:55 PM
Congrats on the milestone!
2013 335is N54 / 6MT / JB4 G5 ISO "E85" BEF map 5 / Fuel: E40 / Phoenix Racing charge pipe / Diff lockdown / 70K miles
I'm addicted to meth but E85 gets me by...
