05-14-2019, 08:42 AM
Originally Posted by Juan_BIGBOOST_TURBO
Hey Terry, I have BM3 in my car, I can flash a .bin file you provide, maybe you'd like to use my car for BEF with stage 3 turbo... HAHA
Sure we can work on it. JB4 log of how it's running now?
Car: M240i
05-14-2019, 09:13 AM
Hi Terry... My phone has a "USB C" connection. Do you know if adapters from Micro to C will work? Just curious. I do have tablets as well, but prefer my phone. Thanks for info.
BMW After BMW
Car: BMW M240i
05-14-2019, 09:15 AM
Yes, the only hard requirement is USB OTG support. Convert all you like.
05-14-2019, 09:57 AM
They do or wait for our USB-C cables. Should be here in a few weeks.
05-14-2019, 10:57 AM
Here they are!
Also, tried to join the whatsapp group chat , isn't it open any more?
webpage: bigboostusa.com
BigBoost's car: BMW M240i
Stage 3.4 turbo
4.8 100-200
10.85 @ 135 1/4 mile
Daily Driver: BMW M235i
BBT stage 3.3 turbo
05-14-2019, 09:02 PM
Here they are!
You could try adding timing to evaluate that, but boost seems fairly OK from what I see. If you just want to go up on boost raise the WMI additive on the JB4 end.
Car: M240i
05-14-2019, 10:42 PM
I'll wait for yours. Thanks for letting me/us know.
Established but no O.G.
Car: 2016 BMW 340i xDrive M-Sport
05-15-2019, 07:52 AM
Originally Posted by dRDiesel
Are you spraying 100% meth on your logs now?
Changed my mind on the Pure stage 2. Just going to stick to the Pure stage 1 to give it some top end power bump....i think the B58 will be perfect around 520whp-540whp.
I've always sprayed 100% meth. I'm considering switching to x98 when my tank runs out.
PS1 sounds like a great compromise.
Car: BMW
05-15-2019, 10:32 AM
No meaning if you look at your logs is your meth showing that it's spraying 100 or is it still around 50-60
2013 335is: V8Bait tuned, M4 DCT flywheel, E50 + AEM meth kit with dual BM5 nozzles, MMP relocated inlets, VRSF outlets, CTS 7" IC, DCI, BMP Stage 2 fuel pump, PR coils, 3" DP, BMS charge pipe
2018 340i: Pure Stage 1 turbo, BMS meth kit, BMS intake, JB4 + MHD, DP
2011 335d: BRR tuned
Car: M240i
05-15-2019, 11:02 PM
Here they are!
Is that 700+whp on B58's stock internals? Logs look healthy, but unlike those I've seen with MHD BEF and stock turbo. Obviously different BEF and setup, but great to see how adaptive the JB4 can be to different setups.
Car: Bmw F30
05-17-2019, 08:59 AM
Is it not be able for b48 yet?
05-17-2019, 09:46 AM
I don't think so. We own a 230i and I'm waiting for MHD to give us the go ahead on it.
Car: Bmw F30
05-17-2019, 06:49 PM
Thank you, Terry
05-19-2019, 10:26 AM
Added latest BEF maps to the first post. I still need to go in there and fix the power gauges, I think we set them all for 680hp lol. Just know those gauges are imaginary and spit out whatever number the tuner types in the flash.
Car: BMW
05-19-2019, 08:33 PM
Good work. The difference between E85_WMI and RACE_WMI is just using either pump for the race file and E40 blend for the E85 file?
Car: 2011 E92 335i X Drive
05-22-2019, 03:34 PM
BUMP
[2017 BMW 340i xDrive] [M Sport] [M Performance Exhaust] [JB4] [BMS BEF] [BMS WMI] [BMS Intake] [CG DS-1] [xHP Stage 3]
05-23-2019, 09:09 AM
Whether using pump fuel or an E85 mix with WMI.
Car: 340ix
05-23-2019, 04:36 PM
So race file is pump fuel? And e85 is a e40 blend?
Car: BMW
05-23-2019, 05:57 PM
Yes sir
Car: B48 330i
05-28-2019, 06:54 AM
x30i B48 10.2:1 engine doesn’t have fuel trim issue. Can I use v13 absolute map on B48 x30i?
Car: F30 340i / E70 X5-35i
05-31-2019, 07:03 PM
OK - I might be totally stupid or just semi stupid...why can't I figure out this MHD thing? I swear I'm doing it correctly. I made a couple of short video clips if they help? I did e-mail MHD support as the WhatsApp invite appears to not work anymore.
Basically, when I open the app, I go to "stock map operations", and when I click on "Flash Stage 0 (Stock Power)", I get connected to the DME, I select my options (burble, speed limiter etc...) of what I want, and then push "Flash"...the car hangs forever and the app goes back to the home screen, and then when I click in that selection again, it says "waiting for current process to finish, if window appears for more than 1 minute, restart device", so I will let it just sit there for hours, nothing happens. I reboot the device, can't start car...then end up using "flash to stock" and I get a % & time until completion, and it is done in like 29 minutes.
Edit: Got it to work under stock map operations...had a bad cable. Ended up using an OTG adapter and USB to OBD2 Cable.
BMW After BMW
Car: BMW M240i
05-31-2019, 08:29 PM
Don’t use stock map operations, try the “flash an MHD map” menu. In there should be a stage 0 option. See if that one works?
Car: 340ix
06-01-2019, 01:08 AM
Is v12 the same map settings at v13
06-01-2019, 06:27 PM
Ended up getting it to work, had a bad cable. I used an OTG adapter with USB to OBD2 cable...looking forward to flashing the RACE map next and getting this WMI operational.
Car: 340ix
06-02-2019, 03:08 AM
This may sound weird but I went back to v11 and loaded up map 5 and the car runs perfect with no boost oscillation or overboost. I tried every map on v13 none ran good
