tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default Can't set TMAP setting to 0 - 04-30-2019, 07:49 PM
I'm trying to leave JB4 connected but run in a stock mode. I've flashed MHD back to a stock map and set JB4 to map 0. I've set steering wheel mode 4-3.
I went out for a ride and it seemed to run ok. I went WOT and immediately got a half engine light. I thought that maybe it was because I've still had the N20 3.5 bar TMAP installed. So, I re-installed the stock sensor and was trying to set the TMAP setting to 0 but I get an error message: "Invalid values in user table. Fix and try again"
I can change it to a 1 or a 2, but not 0. Am I missing something?
At the moment, I re-installed the 3.5 bar sensor back in and with the engine not running but JB4 connected, my boost is reading 0.4psi. Not sure if that helps at all.
Default 04-30-2019, 10:05 PM
Make sure no boost setting value is > 20psi outside the factory sensor range.
tho's Avatar
tho tho is offline
Default 05-03-2019, 11:51 AM
Thank you! That took care of it.
