Car: 2014 435I
06-13-2019, 04:41 AM
Post the actual log not a image of the graph.
'14 435I RWD MHD "Shoup Custom Tune" ° BigBoost Stage 3 Turbo ° Spool FX-150 ° XHP Trans Tune ° VRSF Race Cooler ° VRSF CP ° BMS Intake ° Borla ATAK Exhaust ° Custom Down-pipe ° Stage 3 LPFP ° BMP4 EKP ° M Performance LSD ° Phoenix Racing PI Intake Manifold ° AIC2-P controller ° e85 ° 3.5 TMAP ° NGK 5992 Plugs "0.020"
06-26-2019, 07:04 PM
try this one
Car: bmw e82
07-04-2019, 11:35 AM
What is the latest version of Firmware?
Could someone tell me where to download it?
Thank you!
07-04-2019, 11:37 AM
Depends on the model car! EWG or PWG. Sig says you have E chassis?? This is F chassis.
Vintage
Car: F10 N55 PWG
07-04-2019, 06:22 PM
Loading up the latest PWG firmware.. How has it been working for everyone?
Im assuming the default N55 settings and the duty bias values are for PWG aswell?
Car: 2015 F22 M235i
07-09-2019, 02:24 PM
Is it possible to monitor Meth flow and Ethanol content at the same time on the App? I'm guessing not since both require pin 16 for signal. Just trying to confirm
07-09-2019, 05:05 PM
Yes, it is. There are alternative E85 inputs. For EWG systems we have a V2 board now that has an extra analog input on the DB9 for low fuel pressure or E85 for cars equipped with WMI (that already uses the 2 extra DB25 connections)
Car: 2015 F22 M235i
07-09-2019, 05:33 PM
Thanks for the reply Terry,
Do you have a link for the V2 EWG board? I can't find it on the BMS website. Just to confirm, in order to monitor ethanol content and WMI, the V2 board is required?
Car: F32 435i xdrive
07-14-2019, 04:50 AM
What is the latest firmware for Ewg ? Ewg 17 t2 or ewg 16 test5 ? Im a little bit confused.
Greetings from Germany
435i xdrive
Car: 2015 F22 M235i
07-15-2019, 09:21 AM
Car: BMW M135i
07-15-2019, 01:12 PM
What’s the firmware change log for EWG 17 t2?
Car: 2016 435ix GC
07-15-2019, 01:50 PM
Hey Terry is there a way to fix the Fault code that comes with the EWG harness? I am getting them randomly. I have been practicing the ACC on before Start trick but still is comes up from several times a week at start
JL Bimmer
2016 435ix Gran Coupe
HRP Cold Air Intake, Charge Pipe, Turbo Up Pipe, Turbo Intake Pipe, BMS Intercooler, Axle Back Exhaust, JB4
H&R Springs, Sways, Strut Tower bar, 19"x10 Rotiforms, Too much carbon goodness
Car: 2015 M235i 6MT
EWG 17 t2 -
07-15-2019, 08:27 PM
Are there release notes for the new version? I'm running EWG 15 and wondering if it's worth the upgrade.
Thanks - Ken
Car: BMW M2
07-16-2019, 07:42 AM
Thanks - Ken
Also interested in the release notes!
Thanks BMS for all these updates!
Car: 2014 335i m-sport
07-16-2019, 01:05 PM
Agreed, i didnt even know there was a new version because i always looked at the notes to see if a new ver. came out.
F30 335i | ER Chargepipe | ER Down-Pipe | Wagner Intercooler | BMS Intake | Meisterschaft Exhaust | MHD BEF JB4 Map 3 / 30% e85 / 50:50 Meth
Car: 2016 M235i
07-19-2019, 05:05 PM
Likewise. Would love to update this weekend, depending on what the changes are.
Car: F10 535i
07-22-2019, 08:04 AM
I tried using 17 firmware. However, the boost was 27 PSI with the 7th to 8th speed half accelerator in high gear. I thought that the engine would break. DME error code 101f02 was also issued. I think it is better not to use it because it is dangerous.
2014 535i / ZF 8 / M-Sport / MHD Back-end Flash / XHP Stage 3 / AT / ** / Valve Straight Muffler / FTP Boost Turbo Pipe / Wagner Intercooler /
BMS intake / forge valve
Car: 2015 F22 M235i
07-22-2019, 08:21 AM
Yikes!!
Car: 335Ci
07-23-2019, 03:01 AM
I tried the EWG 17 T2 too, the map 6 that I use, seems to me much less consistent, the boost was like usually, no codes. After turning off the car, the firmware forgets some in dash settings. So I'm back on the EWG 16 T5. Here is everything O.K.
Vintage
Car: F10 N55 PWG
07-23-2019, 01:23 PM
Isnt all 2014 535i's PWG?
Car: F10 535i
07-24-2019, 06:28 AM
My car is an EWG vehicle. The use of the 17EWG firmware was really scary.:eek:
Car: 2017 BMW M2 LCI DCT
07-25-2019, 05:02 PM
Anyone running firmware 17_T2 on a N55 M2? I have a Wagner ** & IC and BMS intake and the car only seems to be hitting 14PSI on Map2, same as it's getting on Map0 !
Car: 2014 F10
User Adjustment N55 Default Settings -
07-31-2019, 03:12 PM
Do I input the N55 Default Settings parameters that are attached to the F Chassis N55 JB4 page into the User Adjustment tab via the iPhone? New to this so I just want to make sure all is set up right...I uploaded the new version of Firmware and selected Map 5 to run. Please assist with the above question, thanks!
08-10-2019, 07:04 PM
I try to get in there a few times per week but if we miss one you can always email us!
Car: f30 335
just a review please -
09-12-2019, 01:23 PM
2019-09-11 19_57_58_Map-2.csv
can someone check these and offer more advise then "go back to map 1"
