Hi Terry, in our M4 race car we are limited BHP per ton, I’m looking to make 464 BHP max
I will be on the dyno in about a week, if I use your BEF what sort of power is that likely to make?
What map number would I use?
Sure, use JB4 map6 to set whatever boost profile you want to keep power where it needs to be!
... if I use your BEF what sort of power is that likely to make?
I’ve also wondered about this for my setup. Not looking for exact numbers, but just a relatively close WAG of the whp / wtq, since I don’t have access to a dyno to truly see what the car is putting down.
2016 F82 M4 / Sakhir Orange / Black extended leather / Opti-Coat Pro
NGK 1-step colder, 0.020" / BMC drop-in, carbon delete / Injen intake & CPs / AR Design catt'd down / AA mid
LCI rear light retrofit / AutoTecknic front splitters / Mode Carbon High Kick rear spoiler / 3D Design rear diffuser
Michelin Pilot Sport 4S 265/285 35-19 / BMS ceramic black exhaust tips / Macht Schnell spacers - 15mm(f), 12mm(r)
Hey,
Bought a second hand jb4 for my F80. I read that newer ones need to be VIN unlocked before installing on a different vechile is this true? It has the Bluetooth connection.
Hey Terry,
I installed the jb4 on my f80 about two weeks ago and I just noticed that my high beam assist isn’t turning on from the stalk, and when i turn my high beams on by pushing the stalk forward the high beam light on the dash isn’t turning on, it does turn on when my pull the stalk back though. Any idea how to resolve the issue?
Hey Terry,
Sometimes phantom issues like that pop up when disconnecting the battery and resolve themselves after a day or two.
Terry, i updated my firmware to last test 11 file, and now wheen the boost come, it dont reach the target, all times midle rpm in wot it hesit to reach the target, like a open/ close the wg varios times.
Im using a rev 2 Bluetooth to uptade firmware and log, it work in f80?
if I'm allowed to mix up to 30% E85 on the S55 with JB4 Stage 3. How much % E100 can I give then? When I had 30% E100 to 102 octane, my trims were way too high at 47-50 ...
Let's see the log, because open loop can also be raised to 70 to help on trims. If you want we also have the back end flash to allow full 100% E85.
It's a very short log but map2 here is an additive map, so that boost target is added to the stock boost as a request. All looks like it's working as it should be here.
There is no E85 within 40 miles. Race fuel is also hard to get around here. I can get trick 101 unleaded but Torco accellerator is way more convenient if same/similar
