tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default Change the default oil change interval? - 07-31-2018, 10:38 AM
I'd like to change the oil change notification to match the interval that I'm using for my oil changes. I monitor my mileage and change it as appropriate, but the car is set to 14,000 miles or something like that and isn't in sync with me.
Is this possible?
Marlinman's Avatar
Car: 335i coupe 2010
Default 07-31-2018, 11:13 AM
You'd probably have to change that with coding somehow. Way above my knowledge. But what I do know, is that you can easily reset the interval each time you change it. Personally, I keep a log book in my car of each interval and change with receipts of proof so that when I sell, they believe that I changed every 5K.
keyap keyap is offline
Car: N55 135i
Default 07-31-2018, 11:39 AM
There's a few posts floating around claiming it can be done using tool32, which you can get hold of for free if you download the usual coding software.
This may help:-
https://www.1addicts.com/forums/show...php?p=20677116
tho's Avatar
tho tho is offline
Default 08-01-2018, 09:19 AM
Thank you for the link! I'll check it out.
