Originally Posted by tho
I'd double check your connections at the TMAP sensor. Are you running a stock or upgraded sensor?
In settings, Under User Adjustment, what is your N20 TMAP set to?
Running a N20 tmap and it's set at 1 on jb4 app
2C58 BOOS PRESSURE CONTROL, DESACTIVATION, BOOSR PRESSURE BUILD UP BLOCKED
2C71 BOOST PRESSURE SENSOR, PRESSURE TOO HIGH
2C83 BOOST PRESSURE SENSOR, PLAUSIBILITY, PRESSURE BEFORE THROTTLE VALVE TOO HIGH
I get those codes except the 2c71 code
