Hi all,
I've read many meth threads in the forum here - many of which are getting dated. I wanted to get the latest status of opinion and options.
I'm looking at the BMS WMI kit.
My largest challenge is currently where to mount the meth tank.
I'll be targetting 50/50, water/meth, for 'stability'.
I'm OK with a 1/2 gallon tank and filling more frequently.
I like the 'under the hood' option for (perceived) simplicity.
A lot of what I read, the trunk is preferred - perhaps the largest reason is to avoid hydro-locking the pump if the water/meth boils.
My car is an E93, N54, 335i, Convertible (less trunk than E90/91/92)
I'd love to see any pictures.
If it has to be the trunk, where to people with the E93 mount? Is there a document showing where to run the fuel lines? (driver side, but where?)
So far, this one looks pretty sweet.
http://www.n54tech.com/forums/showthread.php?t=46153
Thanks!!
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
