Car: F20 M135i
05-31-2018, 07:20 AM
Originally Posted by cnm135i
F&%$ me...+14 AFR???
Everybody runs the car differently. If you push a lot and do many 2-6th gear pulls over and over i am sure afr's or 14's will not have a happy engine very long.
For the occasional dyno or single gear log maybe not that important.
05-31-2018, 09:40 AM
What car is this for? All F series I see are usually in the 15/14 AFR range from factory.
05-31-2018, 10:11 AM
It's a 135i. I don't know why usually on the dyno I can't get good AFR figures, my guess is it doesn't create much load, but on the street this car is running 13.1-13.0 AFR
BigBoost Instagram: @bigboostturbo
webpage: bigboostusa.com
BigBoost's car: BMW M240i
Stage 3.4 turbo
Current B58 record holder: Currently: 822 WHP
4.8 100-200
10.85 @ 135 1/4 mile
Daily Driver: BMW M235i
BBT stage 3.3 turbo
05-31-2018, 11:15 AM
E series N55 likes to run richer than F series, so that is normal. Best is to compare the logs vs the sniffer in the rear to see if it is working. More than likely the sniffer in the back is not calibrated %100. Logs will be more accurate to a certain extent.
06-06-2018, 07:28 AM
The Gray one is DCT. Also Ricardo Saca’s car @135ilove is DCT as well with SSP.
Let me look for some logs for local cars.
Thanks. Do you know if any of the DCT cars are running the stock dmfw? And if so, are they having any misfire issues above 19ish psi?
Car: 2011 N55 135DCT
06-06-2018, 09:50 AM
Im running 28 psi on my DCT with GTX3576R. No misfire.
06-06-2018, 10:06 AM
Thanks. Stock flywheel? What flash are you running? You don't get any unexpected misfires where the log looks perfect but the car throws a cyl 5 or 6 misfire code?
06-06-2018, 11:37 AM
Yes stock flywheel. No issues like that.
06-06-2018, 01:17 PM
Nice. What flash are you running?
06-06-2018, 10:49 PM
Im running bms PI e85 flash with a dct N54 TCU flash zusub number
8606092. DCT launch at 5000rpm.
06-07-2018, 11:19 AM
Thanks. So you’re saying you can go beat on your car all day and you don’t get misfires here and there? like in half mile event, track day, or even aggressive Street driving? Why can you do that and pretty much no one else can run more than 19ish psi without upgrading the flywheel?
06-07-2018, 11:14 PM
Well that i cant tell you. Ive been street tuning my car and no issue. The 8th of July im going to 1/4 mile event. Then i can see. Going to run 28 psi there.
06-07-2018, 11:16 PM
The only diffrence is that i changed my motor awhile back with F series 2014 motor.
Car: BMW 2006 650i, 2014 428i
06-28-2018, 01:47 PM
Tranny no boom?
Car: 11 135i
06-28-2018, 05:04 PM
I ran 25psi daily drags etc no issues stock flywheel.
Car: 2012 135i N55 DCT
11-21-2018, 11:41 AM
Could you give more insight on this, Did your early n55 hpfp and everything bolt into the F series block? and did the DCT bolt right into the motor with the ZF8? And what did you do for the DME? Thanks in advance
2012 BMW 135i DCT, Late E series. VRSF meowless, ARM chargepipe, VRSF 7.5in race FMIC, Fuel it! Stage 2 LPFP- Sold
11-21-2018, 10:08 PM
The only thing i had to change was the HPFP and the connection to block and the sump and valve cover. Gearbox fitted the same. My e series harness worked. All plugs to engine was same.
Car: 135is
11-28-2018, 09:59 AM
Yep, my mistake this was last time we tuned it which was one Race gas, not 93. Well the car has been running like this since Dec. 2016 and engine is just fine, so I don't think its bad.
Sent u a PM
