(#4451)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 01-21-2018, 02:04 PM
Originally Posted by _ink
Bump.
Anyone get BT working with this combo?
Try A214 (newest beta) and ensure you've manually enabled location services for JB4 Mobile from the settings app on your device.
(#4452)
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 01-22-2018, 05:53 AM
Just noticed when you connect to the JB4 while car on idle, u can actually feel a quick change on idle. You can notice that little quick change in idle. Also sometimes happened when you click read error but mostly on the connect. Is that normal due to communication with ECU or something need attention?
(#4453)
Glfdriver18 Glfdriver18 is offline
Car: 2018 Golf R
Default 01-22-2018, 06:27 PM
Can anyone that has a late model iPad and is running JB4 Mobile on it confirm for me that the app supports Split Screen multitasking?
About to pull the trigger on a new iPad Pro but one of the deciding factors is I want to be able to run Waze and JB4 mobile on it in split screen mode.
(#4454)
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 01-23-2018, 08:33 PM
iOS Release candidate looks great! Thanks for working through our feedback.
Just one thing for me on this one. Are you able enlarge the log screen? Everything, from font and line size to the menu that pops up when you select a log.
(#4455)
deemarr 335i deemarr 335i is offline
Car: 2011 E90 335i
Default 01-24-2018, 06:57 PM
What happened to the e content gauge? Why can't I enable it anymore ?
(#4456)
Car: 2008 135i
Default 01-25-2018, 01:05 AM
Sounds possible, but I've not had that on my car. I'd message Terry to see if he's heard of that before.
I'll see what I can do.
Originally Posted by cnm135i
Hi
I have the following problem with the A214 and Connect Kit 3.
If BT is already running I cannot open the app. And I can only connect to the JB4/car if I allow the app to turn on BT... Not much more convenient than just using the OTS when I have to now manage my BT instead.
Hope someone will take a look at this video and tell me if I do something wrong - thanks!
https://youtu.be/Le-maQzTHxs
Huawei Nova
Android 7.0
App Version A214
Make sure you submit the crash report and have enabled your device to send diagnostic info. Once I see where the crash is I can address it. I'll respond in the email thread more.
The E85 stuff has been updated to match the desktop updates. There is a new 'E85' parameter in the gauge selection area. Check the E85 thread on here for setting that up.
(#4457)
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 01-25-2018, 01:15 AM
1)I agree : when you connect to the JB4 while car on idle, u can actually feel a quick change on idle. You can notice that little quick change in idle.
2) when terry updated the PWG N55 To ISO9
The App is sluggish and somtime stop refreashing for 1 sec.
oil temp goes to 1771 always then go back to normal
I think the app maybe cant keep up with the new ISO 9 speed of refreashing.
I am on android A214
ISO9: Redesigned logging engine for much faster sampling of all CANbus channels. Normal speed logging is around 10hz for all CANbus channels now, and slow speed logging remains an option for cars with older software and drops sampling down to around 6hz.
(#4458)
Car: 2008 135i
Default 01-25-2018, 01:29 AM
Sounds more like you have an issue somewhere if you're getting data drops. Email support (in my sig).
(#4459)
Hilly550xi Hilly550xi is offline
Car: 2011 BMW 550xi
Default 01-25-2018, 11:41 AM
Not sure if anyone else is experiencing this. It takes me about 3 or 4 tries to connect to the JB4. Keep on showing an error that I have to check connection. Not a big deal but didn't know if anyone else experience this?
(#4460)
Default 01-25-2018, 02:26 PM
i sent you an email.
but its not only me who is having this problem with ISO, you can go and check the ISO thread.
http://www.n54tech.com/forums/showth...=47223&page=30
Originally Posted by Yoandry
my app started lagging with the ISO updated.
(#4461)
Genesysguy Genesysguy is offline
Car: 2014 335i
Default 01-25-2018, 03:34 PM
The Pixel 2 and Pixel 2 XL are manufactured by different hardware companies.
My Pixel 2 XL works just fine. I'm on the beta channel.
2014 - F30 N55 335i (JB4 / ER Chargepipe)
(#4462)
Car: 2014 335i
Default 01-25-2018, 03:35 PM
I flashed the EWG v 13 firmware this morning and noticed when starting the JB4 app (Which was recently updated), my boost levels start at 5.9 psi for a minute or two before clearing. Any ideas why? I'm on the latest Android beta version. I haven't driven the BMW for a few weeks, so not sure if beta related or something in the new firmware.
(#4463)
Default 01-26-2018, 09:05 AM
Guys we updated to the newer ISO9_T3
The android App is super glitchy in reading the values and gets stuck or too slow
(#4464)
Car: 2008 135i
Default 01-26-2018, 09:49 AM
Screenshot the error.
If it's an issue specific to that engine type or a specific firmware update then there's nothing I can do about it on my end as that will require a fix from Terry.
Possible that value isn't getting flushed out. If you go WOT does it change?
(#4465)
Car: 2014 335i
Default 01-26-2018, 03:04 PM
It sticks at 5.6 psi for several minutes then just clears. WOT has no effect.
(#4466)
Mastalee Mastalee is offline
Car: Infinti Q50 3.0t 2016
Default 01-26-2018, 05:56 PM
Anyone on Android have any luck saving and loading configs for Map 6? Everytime I save it, it shows up like a data log file .csv without the name I'm designating it. Everytime I try to load one it crashes the JB4 app.
(#4467)
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 01-26-2018, 10:26 PM
Thanks for the reply! Are you connecting via BT or OTG cable?
(#4468)
Car: 2008 135i
Default 01-27-2018, 12:28 PM
Try reading/deleting codes when in this state. Does it have any effect?
New beta posted.
(#4469)
Car: 2014 335i
Default 01-28-2018, 03:38 PM
Bluetooth
(#4470)
Default 01-29-2018, 11:01 AM
New beta posted.
Just tested and I can confirm the saving and loading configs is working. Thanks!
(#4471)
Car: 2014 335i
Default 01-29-2018, 11:08 AM
New beta posted.
It had no effect on the initial boost reading.
I did however have a code display: 102A22 MAF, air mass too high. I did NOT have a CEL.
Car seems to be running fine otherwise.
(#4472)
Car: 2014 335i
Default 01-29-2018, 06:30 PM
I just realized it's giving me erroneous values without the car running. I'm going to update to the new EWG_13
_T3 firmware to see if it makes any difference.
(#4473)
Car: 2008 135i
Default 01-30-2018, 09:30 AM
Hi Donnie
I experienced the app partly freezing and not logging some parameters. Dont know if it is app or FW related so I shared with Terry also. Maybe you can have a look.
http://www.n54tech.com/forums/showpo...&postcount=797
Some of the params just aren't going through on that 'frozen' log. Was this after a firmware update or has it always done it?
Have you always had this issue or was it after a firmware update?
(#4474)
Car: 2014 335i
Default 01-30-2018, 09:38 AM
This just started happening. I updated from firmware 12 to 13 and then 13_t to see if it would resolve
It has not. Got a new beta push of jb4 mobile but it didn't fix either.
(#4475)
Car: 2008 135i
Default 01-30-2018, 09:57 AM
Can you try an older firmware file?
Closed Thread
