(#4401)
lightning lightning is offline
Car: BMW 1M Coupe
Default 11-23-2017, 06:04 PM
Hi I’m on the latest jb4 beta IOS app. It seem there’s an issue with the resolution and display.. able to fix this?
Attachment 69445
(#4402)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 11-23-2017, 08:26 PM
Originally Posted by jager335
This is how the latest iOS beta 7679 looks on my iPhone X
Sorry I can't paste the screenshot as it's to big but the app is not centered properly And the dials are only on the top of screen with the rest blanked out in white.
Attachment 69445
The latest beta build is only for iPhone X users with the Needle Fill theme in portrait mode. All other devices should use the previous beta build. I’m hoping to have everything with the UI updated over the next few days.
(#4403)
Car: BMW 1M Coupe
Default 11-23-2017, 08:30 PM
Got it!
(#4404)
Car: 2008 135i
Default 11-24-2017, 03:43 PM
Android users on the beta with Oreo (8.0):
1) You need to manually enable the file permission for JB4 Mobile (in the settings app, permissions, Files, etc.).
2) You need to do the same with Location permissions.
I'm in the process of getting the whole Android app updated to the latest SDK. The SDK update breaks quite a few things in the app (rotation handling, auto-granting permissions, etc.). Bear this in mind when using the beta builds.
(#4405)
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 11-30-2017, 01:22 AM
Is it possible to use both android and iOS (via Bluetooth) with the same account? I have my iPhone as well as an old android (note3, lol) that I keep for flashing. I’m already a beta tester for both platforms, just curious if it will have any ill-effects on JB4 (settings or other) if I switch back and forth between the android and iOS. I’d be glad to test both platforms for you.
(#4406)
AKE90M. AKE90M. is offline
Default 11-30-2017, 01:43 AM
Something blocking your connection to my server. Try another wifi network.
I haven't touched any settings on the JB4 app or have I updated the tablet.
I thought you don't need to be connected to wifi when connecting to through JB4 app from BT?
(#4407)
Car: 2008 135i
Default 11-30-2017, 12:17 PM
Yes, but you may need to reenter your password when switching over to the other device.
Only needs an internet connection once every so often as a security check.
Progress Update:
Spent the past 2 days working through a really annoying bug introduced when updating the base sdk. Happy to announce that is finally resolved. Just a few more adjustments and the new Android beta will be good to go. After that I'll be returning my focus to iOS to get some final betas/public releases rolled out.
(#4408)
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 12-05-2017, 02:08 PM
Is it possible and easy to add select all in the logs? When you want to delete logs and you select select multiple logs sometimes if you have many logs it's easier to have select all in both android and IOS
I had over 100 logs and I had to click one by one to select them to delete or export
(#4409)
Car: 2008 135i
Default 12-06-2017, 03:10 AM
I'll add it in tomorrow.
Android users:
New beta is live. LOTS of changes were made so play with it and let me know if you run into any issues. Email me at support@jb4connectkit.com with bug reports/comments.
(#4410)
salem153 salem153 is offline
Car: golf r 7.5
Default Please help me I got jb4 and jb4 Bluetooth connecter - 12-08-2017, 04:49 PM
When I connect my iPhone 6+ to the jb4 Bluetooth connect
For a second or minutes the jb4 Bluetooth connect disconnect
Please help I check the db9 and the db9 working fine
Help me i need help for this and thanks ❤️
(#4411)
rhodesman's Avatar
rhodesman rhodesman is offline
Default 12-11-2017, 09:33 AM
hey Dmac @ BMS/DMD is there a way to disable the "location signal blocked" warning popup from appearing in the app? Every day I take a tunnel to work and it pops up on my phone and wont go away until I exit the tunnel and hit "okay". It's just annoying because it's blocking most of the gauges and I don't use the GPS speed gauge so I really don't care if the GPS signal is blocked or not. I tried to look in iOS's settings but nothing is there to be able to suppress that warning and it only happens for your app (i.e. Waze for instance does not show this message) so I'm assuming it's app related.
Engine/Drivetrain Modifications:
Trebila tune, xHP stg3, BMS OCC, BMS DCI, VSRF ceramic 3", ER Charge Pipe w/ Forge DVs, AMS Intercooler, Fuel-It Stg3+ LPFP, Pheonix Intake W/ PI, MMPe 1k's
Suspension:
Front & Rear 1M/M3 control arms & Subframe Bushings, MFactory YCW coils w/ Swift Springs
Exhaust:
Berk Street Performance Axle-back w/ straight Midpipes
(#4412)
Car: 2008 135i
Default 12-11-2017, 12:39 PM
Email me. support@jb4connectkit.com
Are you on the public build or beta build?
Android users, trying to get another beta up tonight with a few small changes (Select All in the Export screen for example) and potential BT fixes for the remainder of you with connection issues.
(#4413)
Car: golf r 7.5
Default Hii - 12-11-2017, 12:45 PM
I'm public
(#4414)
rhodesman's Avatar
Default 12-11-2017, 02:32 PM
Public. I do have access to the beta but just not on the phone I'm using for the JB4 Mobile as of now, but I can add it if it's fixed on beta.
Suspension:
Exhaust:
(#4415)
Car: golf r 7.5
Default Hey - 12-11-2017, 02:36 PM
How ?! Help me I'm new for this things
(#4416)
Default 12-12-2017, 07:28 PM
I'm public
The beta vs public answer wasn't for you. He told you to email him....
(#4417)
Car: 2008 135i
Default 12-12-2017, 08:40 PM
Email me with the address you use with iTunes and I'll add you to the beta.
(#4418)
Car: golf r 7.5
Default Hi - 12-12-2017, 10:18 PM
What the address you mean
And what is your email
(#4419)
Default 12-14-2017, 06:17 PM
Hey Donnie, any way to recover deleted logs? Accidentally swiped one off...
Also can you make it an option to update the color of the text for the links to get into the settings? The blue on grey is a bit difficult to see once mounted in the sun in the car sometimes. I think a lighter font color would work better, for me at least.
(#4420)
Car: 2008 135i
Default 12-19-2017, 04:02 AM
Not that I'm aware of.
Get a screenshot of what you're referring to.
iOS Users:
I've uploaded a new beta with better universal support for all iPhones. All 3 themes are almost complete (just need to finish landscape on 2 of them, but this should be functional enough for all devices at this point. The build should be available today after it's done processing.
Android:
Found a few crashes on devices running older firmware (< 5.0). I'm working on those then I'll be pushing for a public release if all goes well.
(#4421)
Default 12-19-2017, 01:43 PM
The blue links.
(#4422)
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 12-19-2017, 02:55 PM
The blue links.
I completely agree. It's almost impossible to read.
(#4423)
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 12-24-2017, 09:20 PM
Has anyone with a Pixel2 XL got the Bluetooth connection working with the app????
(#4424)
Car: 2008 135i
Default 12-26-2017, 12:49 AM
The blue links.
I'll check it out.
Bought a Pixel 2 just for testing and on the latest beta (A207) I have zero connection issues.
(#4425)
Twilly Twilly is offline
Car: 07 335i 6MT
Default 12-26-2017, 10:33 AM
hey guys im having an issue still with having jb4 control boost over wastegate pressures.
heres my log, wonder if you guys can see something im not seeing. Ive checked my lines they look fine. and I have done the proper jb4 BEF and Frimware files.
VM 6266, CKI o2 sensors, stock Map sensor
Please let me know what you think or if you guys have any other suggestions!
p.s first time posting a log so hopefully it worked
Closed Thread
