Car: 07 335i
07-19-2017, 05:24 PM
port injection via aic6 no longer working since v131. It seems to just stay on and flood the engine out. Has this issue been sorted?
2015 FBO 550i msport(Daily)
2007 e92 MT single turbo 335i
07-19-2017, 07:18 PM
No changes have been made, but we haven't supported the AIC6 for some time. Maybe an issue with the map you have loaded on the AIC6.
Car: 335I
07-20-2017, 12:35 AM
My port injection doesnt work with v131 either. Switched back to v130 and it works fine. I use the Jb4 controller.
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
Car: 08 535i
07-29-2017, 10:32 AM
so kb4 pi controller work fine with v13.1?
07-29-2017, 11:05 AM
Let's see a log, you must have something set wrong on v131.
Car: 335I
07-29-2017, 12:57 PM
V130 works perfect for me. If I don't change anything in the settings and update from V130 to V131, how would there be anything set wrong? Unless some settings will change when you update firmware?
07-29-2017, 03:15 PM
Just the log of it not working. Prob set something on WMI page wrong with latest changes.
08-02-2017, 09:50 PM
Firmware and directions are in the first post. I suggest using the MHD back end flash maps posted for single turbo use.
08-07-2017, 09:25 PM
Any update on PI issue with fw 13.1? Mine random stopped working now getting lean afr every pull. I'll upload logs to support section soon.
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
08-09-2017, 05:39 PM
I replied to your support thread for more info. Follow up there if you still need help.
Car: Single Turbo 335i
Single Turbo Logs help -
08-16-2017, 07:49 AM
was hoping someone with a professional eye can take a look at these logs so i can start tuning car and know how its running for now the trims seem to be a little out of wack
08-16-2017, 07:54 AM
AFR is a bit wobbly... What manifold? Timing also indicates you need more octane. With the WG spring so tight this is as low as you can set boost.
08-16-2017, 08:23 AM
Stock manifold and currently running the 11.6lb spring you think i should go even lower?
08-16-2017, 08:27 AM
Sorry meant DOC race manifold I was thinking intake for some reason but it's the DOC race manifold in
08-16-2017, 08:29 AM
You are running a 19psi spring per the log on map1.
What o2 sensors? What fuel mix?
08-16-2017, 09:07 AM
Fuel mix just premium 91 pump gas , stock o2 sensors however they are on their way out they throw codes after a few hard pulls in this summer heat and the spring although this showing over boost is only a 11.9lb spring which is why I'm not understanding why the boost is exceeding 17psi also this is a map 2 log not map 1
08-16-2017, 09:08 AM
Unless the car threw into safety mode after he first pull which I did not see it do but it is possible
Car: 2008 135i 6MT
08-17-2017, 08:51 PM
any chance of adding an additional user defined map in later versions?
with so many different custom set-ups, fuel types and mixes, i think 2x user definable maps would be really handy with their saved FF learning.
be nice to have a Map 6 for BEF Fuel Type A, and a Map x for BEF Fuel Type B.
would make switching from daily or back up fuel source to high octane fuel source much faster.
Car: 08 535i
08-22-2017, 09:37 PM
I couldn't find the old version 1.30 . Mine random stopped working now getting lean afr every pull with v1.31 T16, also injector switched off.
it was not like this with v 1.30
e80,jb4 pi , stage3 fuel pump. stock o2 sensor.
Car: 2007 E92 335i
08-23-2017, 05:14 PM
can you just upload v 1.30 for all of us that are experiencing problems with the new firmware?
08-23-2017, 07:10 PM
If you have an issue with the latest firmware post a log of the issue and we'll help you fix it. Plenty are running without issue. Last issue I came across was someone set the new ethanol settings wrong disabling PI.
08-23-2017, 07:11 PM
WGDC is at 0 yet boost is still sitting at 19psi.
Car: 335I
08-23-2017, 09:41 PM
I reflashed the 131 firmware to give you a log. I cant seem to get the 130 firmware to load again so hopefully you can help me with this soon. Thanks Terry.
Car: 335I
08-25-2017, 12:10 PM
Terry, Can you take a look at my log and see if you can help me get PI working again? Thanks
MAC solenoid -
08-28-2017, 06:24 AM
So after trying even a new jb4 board, my mac solenoid keeps reading 12v to both wires therefore not allowing me to controll boost through out the maps( get wastegate pressure on every map) anyone find a solution to this problem im sure im not the only one that has experienced it????
