jpshoar jpshoar is offline
Car: e60 535i
Default Valve Cover Gasket Replacement - 07-31-2017, 06:43 PM
I had a rough idle this morning and decided to do a spark plug change. While taking off the engine cover I noticed oil around the plugs (pictured below). Would I need a new valve cover or would a new gasket with new bolts be sufficient?
XM-N54 XM-N54 is offline
Car: 2008 BMW 335xi
Default 08-01-2017, 08:53 AM
While replacing the gasket, look for cracks! Either way you will need to do the gasket. You're prob better off just getting a whole kit and changing cover as well.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 08-01-2017, 09:10 AM
As long as the valve cover is not cracked or warped and you don't have any PCV issues, you probably don't have to replace it, although at very high mileage it might be worth doing as preventative.
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 08-01-2017, 07:10 PM
PCV issue from a cracked valve cover?
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
pysical pysical is offline
Car: 2009 335xi
Default 08-02-2017, 07:54 AM
Looks like a crack just to the right of the injector fuel rail to me.
Pessimistic Poster
Car: 135i N54
Default 08-02-2017, 08:22 AM
Not from being cracked, but the PCV valve screws into it and there are various channels that run through the cover which can get clogged with carbon/gunk. I remember someone once sawed and old one in half and it was almost completely blocked off.
Venom77's Avatar
Car: 335I
Default 08-02-2017, 11:15 PM
Thank you, Im replacing my gasket this month and will look for that too.
