_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default PI & Meth Setup - 07-31-2017, 06:03 AM
As discussed in the PI thread, and creating a separate support thread - I am trying to have PI and METH setup to work concurrently.
I'm an early PI adopter, so using the AIC6 as the controller, have also confirmed orange wire pin location per Terry's suggestion.
Car: E92 N54 335i
Mods: FBO, Upgraded Twins, Stage 3 LPFP, PI, Meth, E85, etc
Meth settings are verified as:
sch4400 sch4400 is offline
Car: 08 535i
Default 07-31-2017, 06:53 AM
Meth safety mode and trigger mode is corrected. also you can set 3 , 0 if you run maps 3, 6, and 7 (default operation).
anyway, could you show me the Photo of WMI page ?
Default 07-31-2017, 11:21 AM
Running PI and meth concurrently with the SS controller is not an issue, it's just not recommended. You can run and monitor meth normally as there is no wiring conflict with the SS controller.
_ink's Avatar
Car: 335i DCT
Default 08-03-2017, 04:11 PM
Here are my WMI settings:
_ink's Avatar
Car: 335i DCT
Default 08-03-2017, 04:18 PM
Hi Steve, the issue I have is that it's not working despite settings being confirmed.
Is there a minimum requirement from a firmware perspective?
Default 08-03-2017, 04:40 PM
Have you tried lowering your additive?
_ink's Avatar
Car: 335i DCT
Default 08-05-2017, 05:42 PM
Lowered to 65, Steve.
This wouldn't impact the ability to prime the system right? Because this isn't working...
Default 08-06-2017, 05:06 PM
No, it won't affect the ability to prime...if you can't prime that is likely a hardware issue.
Setting it to 80 when the max setting is 75 can cause issues though.
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 08-07-2017, 04:32 AM
@ Steve why will cause issues, he got N20 Tmap so it's fine up to 100 though.
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
Default 08-07-2017, 11:10 AM
Depends on the firmware version...some go higher and others don't
