(#1151)
Default 07-09-2017, 02:24 PM
Stock injectors will be fine with E85.
Stage 2 LPFP will be required to run 100% e85, even on stock turbos. In addition, if you are making over 430whp and running 100% E85, you will also need PI as the HPFP won't be able to keep up. Stock turbos are capable of 460-475whp, 500 if run really aggressively.
MTD MTD is offline
Default 07-12-2017, 04:58 PM
Whats for Type Injektors its in the Kit standart LS1 LS2 LS3 ??
Thank you now for the answer
megaman416 megaman416 is offline
Default 07-13-2017, 01:25 PM
Just finished installing my Fuel-it meth port kit with BMS controller. Not seeing flow on the jb4 meth gauge on my tab. Is there anyway to see it's working? My iats are falling drastically so I know it's working. Still need to do a log. Thx
TM TS 6466 Powa!
///Monst3r ///Monst3r is offline
Car: 07 335i
Default 07-21-2017, 12:15 AM
How does this work with the methanol port injection? How do you prime the system? Does it stay primed? Is there a pause before boost goes up while the pump builds pressure and between shifts when the meth pump is off? Does the controller spray the injectors right away or when certain criteria are met?
2015 FBO 550i msport(Daily)
2007 e92 MT single turbo 335i
Default 07-21-2017, 11:04 AM
To prime the system, you will disconnect the methanol fuel line adapter, purge it, and reconnect it. Then do a couple drive cycles and the system will be purged and stay purged.
Alternately, on our rail you can install a purge line if you wish with the return port.
You are no longer using nozzles with this system, you are using injectors (solenoids) that close completely, so the system stays primed. That is the problem with using more than 1 meth nozzle, the nozzles do not close and the system drains back to the solenoid.
Injection is based on boost and RPMs.
Car: 07 335i
Default 07-21-2017, 01:36 PM
Thanks Steve!
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 07-28-2017, 04:53 PM
Meth safety would have to be set to 3 if there will be no feedback signal from the FSB.
Hi Steve, settings and wires (orange wire) have been verified, and still no meth flow...
Is there something else that needs to be done?
Default 07-30-2017, 09:30 AM
Create a thread in the support section with all your information.
threethirtyfive threethirtyfive is offline
Car: 335i e90
Default 08-10-2017, 05:39 PM
Just double checking here... FuelEn is now the PI tracker, correct? Just installed my setup and while I don't see anything in the meth column I do see numbers that would make sense for a PI setup.
'07 e90
Default 08-11-2017, 01:13 PM
That is correct...to see the meth trace, you will need to set meth scaling to 100 and be running a BMS controller. In addition, at low injector duty cycle that signal may not show up.
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 08-12-2017, 04:14 PM
Trying to use the BMS PI controller to trigger my stage 3 pump. Negative goes to the orange wire and positive goes to 12v signal?
2007 AW 335i E-92 6AT MMP Stage 3 @ 25psi / JB4 G5 ISO / XHP STG3 / VRSF D-Ps / MMP INLETS&OUTLETS / WEDGE MHD E50 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / PR STAGE3 LPFP 10.92 @ 132 1.72 60ft 6.96 @ 103 1.55 60ft
Default 08-12-2017, 04:39 PM
No...orange wire is 12 volts
Default 08-12-2017, 04:45 PM
When I do that it makes the pump kick on as soon as I connect my pump to the battery negative
Default 08-13-2017, 03:16 PM
The orange wire sends a low current +12v signal out to the relay. The JB4 is setup currently to output this signal under any PI flow.
Default 08-14-2017, 03:42 AM
Thanks Terry. I'm going over the setup for the wire harness this morning with Rob from PR. I'm using his pre assembled harness.
Car: 335i e90
Default 08-14-2017, 01:00 PM
Fixed. Once I added the 2-step chip all was well, the issue was I used my MBP which has had some issues logging this data in iOS. Used my PC on the way home and we are in business!
'07 e90
Default 08-15-2017, 11:23 AM
chadillac2000's Avatar
Car: 2008 535i
Default 08-15-2017, 11:41 AM
Hey Steve/Terry,
Any updates on possibly getting around to implementing a faster cut-off when a misfire is sensed?
I'm about to upgrade turbos and implement PI, but even though I'll be using the BMS controller, adding PR coils, am up to date on maintenance and have realistic power goals, creating a hyperlean condition seems like something I would constantly be losing sleep over.
Default 08-15-2017, 11:43 AM
It's turned in to largely a non-issue with our current implementation. FYI for manual trans cars we use the clutch wire (part of the NLS system) for instant cut off.
wlld1984's Avatar
wlld1984 wlld1984 is offline
Car: E90-N54
Default 08-27-2017, 07:36 AM
I have finished installed my Fuel-it meth port kit with BMS controller. I have no idea whether the PI work.
I use port injection along with my water/methanol injection kit.and the meth nozzle work good,but not seeing flow on the jb4 meth gauge.
2017-08-26 15_48_40.csv
2017-08-26 11_28_53.csv
JB4 PI Controller blue and orange wires (which question mark) stay disconnected
FSB orange wire goes DB25 spot#2;blue wire stay disconnected
Whether i got the wrong wiring?
E90 335 AT|JB4 G5 ISO |TREBILA flash|anti-lag|VRSF 7"HD FMIC|N20 TMAP |BMS METH|3" **|walbro 455|Forge DV | RB PCV |DINAN oil cooler|XHP stage 3|MMP PI|MMP inlets|MMP outlets|MMP turbo
Default 08-27-2017, 09:58 AM
Orange is used to trigger a 2nd fuel pump, blue is not used, deleted off newer units.
In your log you have a meth signal that mirrors the fuel enrichment request signal, so seems like the injectors are being powered up. Whether or not you have WMI pressure behind the injectors we can't tell from your implementation.
kisarci kisarci is offline
Car: 07 335i
Default 08-29-2017, 12:06 AM
This may be a stupid question but I currebtly have the ADE PI setup. I was wondering, could I use the injectors that I have from my ADE with the jb4 controller?
07 335i e92 |FBO |MMP Inlets relocated |ADE PI |MF LSD
Default 08-29-2017, 09:15 PM
That would be a question for ADE but I believe everyone is using the same connection type.
BeGooD69 BeGooD69 is offline
Car: 2007 335i
Default 09-01-2017, 03:07 PM
Where does the esensor plug to in this pi controler/jb4 setup!! Db25 pin 2?
Also I think my st3 relay is confusing... orange on PI controler goes to + trigger on fuel pump relay? And - trigger now connect to ground right?
Default 09-01-2017, 03:18 PM
Are you using a PR harness?
