(#2626)
Default 05-11-2017, 09:47 AM
Originally Posted by defineste90
I need some help with tuning on my car. Im located in Wilmington DE. I have a single turbo car that i want to have a tune done for everything tuning wise is JB4 on my car so i prefer someone that knows this system along with single turbo 335s. I have big plans for the car and reached out to burger on this and they referred me to this thread to help find me a tuner for this application.
We can give free tuning advice via our support forum. But if you need a lot of individual help you'll want to hire a tuner. I know David is popular around here.
defineste90 defineste90 is offline
Default 05-11-2017, 10:14 AM
thanks terry i sent Jon over the build of the motor and not sure if i could get it to be where i want with the tweaking that i can do car was built for over 1000whp and i intend to make it there i just know it will take a more in depth tunewhere is david out of so i can get in touch with him
Jim Jim is offline
Car: 2008 BMW 335i
Default 05-13-2017, 08:07 AM
You might try Justin Larivee. He has a Company in Florida called boost addictions. He helped me with my single turbo tuning by e-tuning. He's familiar with Jb4 and mhd flash. He was a pleasure to work with for me. He charges $50.00 for a custom tune.
Grand_hustle17 Grand_hustle17 is offline
Car: 07 335i 6mt
Default 05-15-2017, 02:47 AM
Im looking to update the firmware, and either im overthinking the post or i cant find that 13.0 firmware update?
enrita's Avatar
enrita enrita is offline
Default 05-15-2017, 03:51 AM
First post
500hp500tq 500hp500tq is offline
Default 05-18-2017, 12:17 PM
Do we want bit1 Disable wastegate adaption enabled if using DB tuning?
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
Default 05-19-2017, 08:12 AM
This still true on ST firmware 13.0??
Originally Posted by FutureUseD and other settings
*Meth Safety Mode All Versions
0 - Raise boost on map3 as a function of meth flow & historic timing (default)
1 - Raise boost on map3 as a function of meth flow only
2 - Start at normal target and failsafe IF flow drops below flow level for 1 second under boost. Enabled for all maps.
3 - When on map3 meth flow is completely ignored. Useful for using map3 as an adjustable non-meth map.
4 - Run a progressive meth safety on all maps
*Meth Trigger Mode All Versions
0 - Meth flows on maps 3, 6, and 7 (default operation)
1 - Meth flows on all maps
2 - Meth flows on map 3 only
3 - Meth is disabled on all maps
"stock"
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
Car: 2009 E93 335i Sport
Default 05-26-2017, 11:56 AM
Originally Posted by Eleventeen
Terry, are you planning to adapt the twin-turbo firmware to work with the single turbos as well (maybe have a toggle in the interface)? Or are you going to develop specific firmware for the single? Honestly, the twin-turbo firmware doesn't seem that far off.
Quoting you because you have the Turbo I was going to run, 3584rs is the new hotness that should be happy at 1 bar daily on 94 Octane ethanol free fuel and 2 or 3 bar on kill on race gas, why doesn't anybody run leaded race gas with the DI, does it **** up the fuel system?
Blaine B.'s Avatar
Default 05-27-2017, 12:00 AM
Originally Posted by mjmarovi
Forced Performance HTA 3794r. Go big or go home! Lol
^There's a man with style and taste.
lllN54lll's Avatar
lllN54lll lllN54lll is offline
Car: 335i N54
Default 05-30-2017, 03:00 AM
Terry, can you please add this option to the MAC firmware.
"Added metric M3 dash setup under menu 5/7, moved startup sweep toggle to menu 5/8. "
thanks
ninjacoupe ninjacoupe is offline
Car: 135i..First of the 1
Default 06-17-2017, 12:38 PM
Is it possible to get a lower oil temp safety for boost. I know from 140-150 there is some change in oil viscosity and very little change past 160 but the oil is pretty well thinned out by 140-150 and the majority of the oil is being used for cooling in a BB turbo. Some factory turbo systems I believe are set as low as 130. Its a great safety and from a cold start I do not mind the time to get everything up to temp, but after sitting a few hours in a lot and looking to play it can be a bit embarrassing telling someone to wait for that last few degrees. Maybe a change for starts above 100 degrees we can get full boost quicker. The turbo with the blanket is already at operating temps in these situations.
N54_ST_6266_Russia N54_ST_6266_Russia is offline
Car: BMW1M
Default 07-08-2017, 01:35 PM
hello guys, I have a problem with high pressure fuel. I installed new hpfp, and 2 walbro 400 lpfp. but the problem is gone
Car: BMW1M
Default Log - 07-08-2017, 01:42 PM
Ron100, no meth
20psi and 17psi
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 07-08-2017, 10:50 PM
Can I ask when V131 was added?
I just updated today from V130 to V131 and my PI didnt work. I loaded V130 back into my Jb4 and PI is working again.
Venom77's Avatar
Car: 335I
Default 07-11-2017, 11:52 PM
Any Ideas?
gold335 gold335 is offline
Car: bmw335i
Default 07-12-2017, 01:26 PM
We need more support regarding V131 settings!!!!
Default 07-12-2017, 01:39 PM
What do you need to know??
Car: BMW1M
Default 07-14-2017, 01:33 PM
😩😩need help!
Default 07-14-2017, 01:34 PM
Time for port injection or WMI to take some stress off the high pressure pump!
Car: BMW1M
Default 07-14-2017, 01:59 PM
17psi - low boost... hpfp must keep the pressure
Default 07-14-2017, 09:03 PM
You can try swapping the high pressure pump for a new one... But depending on the fuel mixture you could be making a lot more power than you think running 17psi @ 6400rpm...
Car: BMW1M
Default 07-15-2017, 02:39 AM
New hpfp...
e36luv e36luv is offline
Car: 1998 M3 GT3582R
Default 07-19-2017, 07:12 AM
First log on single turbo map1 looks lean. What do I need to adjust before going to map2?
VM 6466
Stage 2 LPFP
Adv o2 sensors
Well I can't upload the log from my phone but I will after work
bradyzq bradyzq is offline
Car: anything that's on the dyno
Default 07-19-2017, 11:21 AM
I'm using the BB ST BEF for I8A0S, pump gas.
4bar MAP.
I installed the single turbo firmware, and am running the most recent interface.
I followed the recommendations for ST duty bias and FF starting points, then moved up.
The wastegate spring is only 5psi.
With FF at 150, and duty bias at 100 across the board (tripling underlying number, correct?) I still severely underboost. Any ideas on how to reach target?
I realize the spring is weak, but wgdc is nowhere near maxxed.
Car actually is single turbo GT35ish sized 2007 335i MT.
Default 07-19-2017, 12:03 PM
Never mind.
Duty bias at 1500rpm must be 50.
