SamJ SamJ is offline
Car: BMW 335i
Default what oil are you E85 guys using? - 07-02-2017, 02:25 AM
Hi guys
did a search seems most are either running Mobil with a few using Motul
Ive been running Motul 300V 5W40, E90 335 JB4 Bolt ons 2/3rds E85 mix
wondering what others are using?
guru_method guru_method is offline
Car: 09 AW 135i
Default 07-02-2017, 02:41 AM
Amsoil, can't say enough good things about it been using it for years on all my cars. Top notch.
2009 135i ///M Sport - 6 SPD
JB4 . MHD . E85 . FUEL IT! STG 3 . FUEL IT! PI . BMS DCI . ER CP . PURE STAGE 2 . RB INLETS . OUTLET . SYNAPSE DV . WAGNER EVO 2 . UR DOWNS . HPF EXHAUST . 335is CLUTCH . MFACTORY SMFW . BC COILOVERS . M3 SUSPENSION . M3 VERT SWAY BAR . M4 PLUGS .
Car: BMW 335i
Default 07-02-2017, 02:52 AM
thanks
curious what weight you are using and what sort of ambient temps you see where you live?
we see 5 degree lows in winter 30+ degree highs in summer Celsius
some days we see closer to zero and in the summer 45+ sometimes but those are extremes
Boss86 Boss86 is offline
Car: 2007 Bmw 335i
Default 07-02-2017, 09:40 AM
Originally Posted by SamJ
Hi guys
I'm using 0w-40 penzoil euro formula it hold up pretty good, doesn't seem to burn as quick and it's still pretty clean..
Traf Traf is offline
Car: 2009 135i Coupe
Default 07-02-2017, 10:35 AM
Motul 8100 X-Cess 5w40, very similar to the 300v, a lot cheaper.
f*** v-bands clamp
Car: 2007 Bmw 335i
Default 07-02-2017, 10:42 AM
thanks
I'm in Dallas TX. It's pretty warm here. Winter we may see high teens and summer 106ish. So far it's been in the 90's but I generally don't drive the car too hard when the temps are hot out.. I usually try not to even be out if I don't have to lol
seroga1986's Avatar
Default 07-02-2017, 04:05 PM
Redline 5w40
2008 135i Sport 6at
2013 X3 xDrive28i M-package
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 07-02-2017, 09:20 PM
Pennzoil Ultra Platinum here.
Chris@VargasTurboTech's Avatar
Chris@VargasTurboTech Chris@VargasTurboTech is offline
VTT ***** *****
Car: All Things Booost
Default 07-02-2017, 09:39 PM
MOtul 8100 x-cess. Tony loves Amsoil.
Chris - VTT Forum Representative
For fastest response: Chris@Vargasturbo.com
www.Vargasturbo.com
Default 07-02-2017, 10:00 PM
Motul 300v
Torco
Car: 09 AW 135i
Default 07-04-2017, 12:04 AM
thanks
I'm near Dallas as well, we seem to have somewhat similar ranges in temperature than were you live.
I put a link in my original comment for the Amsoil, its 5w40. Pay for membership $16/year you'll get good discount.
