06-19-2017, 07:01 AM
i should probably chime in here.. i am running PI via the orange wire through the second output. I'll send my logs over to Terry to get his thoughts, but looks good so far overall.
06-19-2017, 01:38 PM
Originally Posted by _ink
Hey Steve, my meth settings are:
Meth Safety: 2
Meth Trigger: 1
Meth safety must be set to 3 if you are running meth and no return signal.
Car: e92 335i
06-24-2017, 02:06 AM
I need some instructions for dummy  .
I cople questions about JB4 PI controller assembly.
First, instructions im page 1 says:
"Purple goes in the JB4 small gray subconnector #21 as read from the female side"
Doers this mean that side of subconnector where all wires are red?
And the blue wire from controller, that is going to stage 3 lpfp relay?
Hope You understand my poor English, and help me whit thease issues
edit:
My JB4 box is 2013, do I need new chip to JB4?
F20 M135 xDrive 445 bhp
Ex:E92 335iA N54 610 bhp, E93 335iA N54 460 bhp
06-25-2017, 11:12 PM
Blue wire is not used at this time.
Pin 21 as labeled on the stock female connector.
Yes, you will need the anti-lag chip.
Car: 335i DCT
06-26-2017, 03:44 AM
Do you need to be on a particular version of firmware for this Steve? No joy here.
06-26-2017, 05:00 PM
Not sure what you mean.
You have safety set to 3 and trigger set to 1?
Car: e92 335i
06-28-2017, 07:12 AM
Thaks Steve
So how does the second pump activate in LPFP if BMS JB4 TBI controller is not given that information? I dont use hobb's switch...
Pin 21 as labeled on the stock female connector..
Yep, I got it now, but I sill don't understand why you can't just say
male side of connector, slot 8?
Yep, I just make an order.
06-28-2017, 09:46 PM
TBI controller? You mean PI controller? If so, that doesn't use a Hobbs switch and the Hobb's switch can be used to trigger the secondary pump.
Female 21/Male 8 on gray connector = same thing but adding more instruction just tends to confuse people.
Car: e92 335i
06-29-2017, 05:28 AM
Thank you Steve for your patience
Sorry, my bad, I mean PI controller. So I do not need a Hobb's switch because PI controller is trigger the secundary pump? (blue wire from controller)
Its not always so simple when you are not native english
Car: E92 335i
06-29-2017, 05:48 AM
Just got my BMS PI Controller this week, i was going over the wires and went thru this thread, I saw that Blue is not used at this time but didn't really see much details on the Orange wire. Do i need to tape that off or use it somewhere?
06-29-2017, 06:26 AM
it depends on how you intend to trigger the secondary LPFP. If your using a hobb's switch then yeah tape it off.. if not connect to the 12V coming from the trunk
Car: E92 335i
06-29-2017, 06:34 AM
Ahh got it, thanks. Not doing secondary pump or anything so I'll just tape them off.
Car: 335i coupe
06-29-2017, 11:55 AM
To simplify things, is there a wiring diagram drawn up for the BMS PI controller on the download page? I think that would clear up much of the confusion and keep you from answering the same questions over and over.
Car: e92 335i
06-29-2017, 12:55 PM
You mean this:
And in yhe box:
Dont find any mention about that blue wire...
Car: E92 335i
06-29-2017, 01:00 PM
Originally Posted by kt0510
You mean this:
And in yhe box:
There no mention of the Blue Wire or the Orange wire. I read through most of the 46 pages in this thread and they were mentioned once or twice. It may be new or it may be something only with BMW PI controller.
06-29-2017, 01:01 PM
Gets confusing as there are 2 different controllers (BMS and AIC), and then on the BMS some wire colors have changed or been added depending on vintage, and then 3 different applications for install (E N54, N55, F N55/S55).
Car: e92 335i
06-30-2017, 06:01 AM
Only one question about stage 3 LPFP, if I don't use Hobbs switch, how I get trigger to secundary pump?
Or is Hobbs switch the only way to trigger LPFP (secundary pump)?
Car: 335i DCT
07-01-2017, 07:57 AM
As in, there was no option to be able to use meth and PI together when i initially installed (i was one of the early ones).
Now we are saying this can be done? So there must have been a firmware change for this to occur?
07-02-2017, 11:32 AM
It's never suggested but it is possible. You have to turn off the meth safeties if the JB4 can't monitor the meth signal.
Car: 335i DCT
07-03-2017, 01:44 AM
Yes, Meth safety is set to = 1.
Do you have a photo of how the wiring should look when running PI and Meth?
Car: 07 BMW 335i
07-05-2017, 05:49 PM
I think Terry answered your question on post 1110?
07-05-2017, 05:51 PM
Meth safety would have to be set to 3 if there will be no feedback signal from the FSB.
Car: 335i DCT
07-08-2017, 07:01 AM
It is Steve:
07-08-2017, 05:19 PM
Is there anyway to test fire the injectors using the bms controller with the car off to check for faulty injectors ?
Car: 2007 335i e92
07-08-2017, 05:27 PM
Thinking about getting port injection and stage 2 LPFP. I still have stock turbos so I was wondering if I would even make any more power with it? Also, would running 100% E85 ruin my injectors?
2007 335i e92 Montego blue. JB4 Tune, Backend flash, VRSF C4tless D P's, VRSF Intercooler, VRSF Chargepipe, VRSF Relocated inlets, HKS BOV, Beluga exhaust. 30% e85.
